fuel injector leak
fuel injector leak
i pulled my fuel rail up today, and when i primed the fuel rail cylinders 6 and 8 squirted fuel. i tried it again but they wouldnt do it again. but when i actually cranked the motor those two injectors shot more fuel than the others. does this mean its time to replace the fuel injectors? any help is grately appreciated. i also have a glowing red manifold, the same spot that 6 and 8 are at, so im guessing this could be related.
yeah it's time to replace, no fuel should come out just from priming
edit: he checked the fuel pressure in another thread and took the vacuum line off the regulator and didn't mention anything about gas shooting out so it should be good
Might want to check those two injector pigtails too. If the wiring is shorted to ground with the key on, those two injectors will just hang open (the PCM fires them by pulsing a ground signal on one wire while the other supplies a constanf 12v+). The pink wire is the 12v+ and the other colored wire is the ground.
hmm.. didn't realize that faulty wiring would cause that! i had to re-wire two of my injectors because of cracked/shorting wiring, but mine wouldn't work at all.
learn something new everyday!
That's the easiest most straightforward way to test.
And since the injector is hanging open of course it will spray fuel when the fuel pump primes. It only runs for 2 seconds and then shuts off.
doesnt a noid light just plug in where the electrical pigtail connects to the injector? thought u just hooks those up and it lights or doesnt. how do you do it by the different wires? sorry i get confused with wiring lol
so i know stock is 24 lb injectors. can i buy any brand and be ok as long as it is a 24 lb injector? i dont wana tune my pcm yet since car is stock
try to stick with a oem lt1 injector, a 24lb/hr injector intended for 50psi fuel pressure will flow differently than a 24 lb/hr injector intended to run at 70psi.
if you can't find any there's a chance i might part with my stock ones.
