having problems putting gas in my gas tank
Old 02-16-2011, 11:43 PM
texas outlaw's Avatar
Default having problems putting gas in my gas tank
it takes me like 10min. to put 8 bucks of gas in my 94 z28, it goes in but a little at a time, could it be a vent hose or something like.
Old 02-16-2011, 11:45 PM
confederatelt1's Avatar
do you use the same gas station all the time?
Old 02-16-2011, 11:46 PM
no anywhere i go i have the same problem
Old 02-16-2011, 11:48 PM
what happend when your trying to fill it? the pump clicks or.... ?
Old 02-16-2011, 11:52 PM
tricked94camaro's Avatar
sounds like somebody stuffed something in your filler neck. old high school prank lol that and super gluing the valve caps on the tires hahaha
yea i try and force gas in and the pump will just click and it will just spill gas it wont go down but i can run a piece of hose all the down the gas tank, to me feels like a vent problem
Old 02-16-2011, 11:56 PM
RamAir95TA's Avatar
The tank vent might be clogged or broken.
Old 02-16-2011, 11:57 PM
yeah thats most likely what the problem is. same thing happend on my dual tank cummins. it would just click cause there was a vent problem between the 2 tanks. took me 30mins to fill up the front tank.
Old 02-16-2011, 11:58 PM
what do i check or how do check that?
Old 02-17-2011, 03:34 PM
azmarkus's Avatar
I had a similar problem not too long ago, I'm the farthest thing from a mechanical genius so read and proceed at your own caution. Part I - I was having the problem at an older gas station with the filler necks that are somewhat shorter, went to a newer station with the longer filler necks and it improved. Part II - I let the car get down to a 1/4 tank, before I drove to the gas station, I undid the gas cap and gave the car a good couple of bounces off the back end (this was something an old-timer suggested to me), put the gas cap back on, went to the newer gas station again and it's been problem free ever since. Could be air in the lines, could be a bad purge solenoid (which I think are on top of our fuel tanks...oh joy), I don't know if that would throw a code or not. Again, it's painfully obviously I'm not a mechanic, just some homespun remedies that might or might not work.
Good luck.
94 Z28 M6
Quick Reply: having problems putting gas in my gas tank
