help me calculate my compression ratio..
Old 02-22-2011, 11:25 AM
speedracer2536's Avatar
Default help me calculate my compression ratio..
ok sooo i am curious what my cr will be..
3.480 crank
5.7 rods
http://www.summitracing.com/parts/TRW-8KL2256F30/ These pistons
55cc heads
stock deck.. Im pretty sure it wont be cut..
impala head gaskets
Old 02-22-2011, 11:37 AM
qc97z's Avatar
The description of the pistons says the dome volume is +6.10. If this is put into the calculator on Eagle's site, here's what you get:
Deck Clearance .022"
CR 13.35:1
355.1 CID
Assuming the dome volume is for valve relief, it would actually be -6.10cc. This gives you:
CR 11.23:1
355.1 CID
I don't think you want to go with stock deck. It should be milled just to be sure everything's kosher with flatness.
Old 02-22-2011, 11:38 AM
ahhhh ok.. I will prob. get a fresh surface on it just to be safe like you said.. Wheeehhhwwww i was worried.. I got 16.26:1... freaked out for a minute.. haha
Old 02-22-2011, 11:46 AM
qc97z's Avatar
Well, I put in the stock deck height at 9.025", and .026 head gasket thickness, which is impala if I remember correctly.
If you mill the deck down to 9.00" flat, your piston will be .003" above the deck surface, which is bad.
With the setup you propose, the most you can take off the deck is .020", that leaves you at .002" deck clearance with. -6.10 CC piston is 11.87:1 compression, but a +6.10 as advertised on the link you supplied to the pistons gives you 14.29:1 compression.
In my opinion, you need to deck the block, and either go with a thicker head gasket or dished pistons with negative dome volume. The current setup you propose will be very tricky, and dangerous in my opinion.
Old 02-22-2011, 12:01 PM
Ok so i called summit.. The +6.10 is the volume of the valve relief.. They are FLAT TOP not dome.. So no worries there.. HKE calculated out the compression to 11.2:1.. So i think it will be good to go..
Old 02-22-2011, 12:13 PM
qc97z's Avatar
umm....I don't think that's correct. If you deck that block as low as you can (to .002" clearance), you will be at 14.29 compression. That's at 9.005 deck height...only taking 0.020" off the top.
You gotta change something.
Old 02-22-2011, 12:32 PM
Puck's Avatar
You will be fine.
Even if you zero deck the block you will be around a perfectly fine 11.8:1.
As the block stands now you will have 11.1-11.2:1.
Qc, you are using 6.1 as a positive number as if it were a dome piston, but it should be inputted as a negative number since it is a flat top with valve reliefs.
Old 02-22-2011, 01:22 PM
x2 for this.. i mis wrote.. Thats +6.10 is the actual volume of the relief.. They do not extend up.. They are inverted.. so the physical volume is a positive number but the actual effect is negative..
Old 02-22-2011, 02:24 PM
qc97z's Avatar
Nice. Summit's spec is a typo then. +6.10 would imply a dome. -6.10 implies a dish or valve relief.
Old 02-22-2011, 02:26 PM
I do agree with you on that.. It is confusing
Old 02-22-2011, 02:41 PM
WS Sick's Avatar
If you havent ordered these pistons already I would find a simular piston with the 1/16th ring not the 5/64s, biiig difference is drag between the two.
Old 02-22-2011, 02:53 PM
I actually just ordered them.. This motor will be getting spray..
Quick Reply: help me calculate my compression ratio..
