tps
How did you know your old one is bad?
Stock voltage with the key on, engine off on the blue signal wire should be between .2v and .9v (ideally ~.6v) at closed throttle and increase proportionally with throttle position about four more volts.
What do you mean "I feel like I'm having to push the gas threw the floor board." You need to be WAY more specific in order for us to help you. Specifically, how is the car acting?
