What thread sealant
Old 03-08-2011, 04:34 PM
jaycenk's Avatar
Default What thread sealant
Hey guys I am gona try and replace the head gaskets before I need shoulder surgery. What thread sealant do I need for the head bolts? They are ARP head bolts and summit sells this http://www.summitracing.com/parts/ARP-100-9904/ Is this little tube gona be enough or do I need a couple of them or should I use something else? I am tring to get all the parts from summit since I have some summit bucks. Thanks
Old 03-08-2011, 04:40 PM
noice's Avatar
Liquid Teflon Pipe Sealant w/PTFE is what you want. Tube might not be enough, but a local parts or hardware store will have what you need. The stuff is really cheap.
Old 03-08-2011, 04:41 PM
gregrob's Avatar
Permatex High Temperature Thread Sealant
jaycenk's Avatar
Cool thanks man
Old 03-08-2011, 04:42 PM
gregrob's Avatar
Thumbs down
It needs to specify high temp
Old 03-08-2011, 04:43 PM
97REaper's Avatar
I use Permatex Thread Sealant High Temperature 59235
Old 03-08-2011, 06:22 PM
TravisMcGill2000's Avatar
any body ever use the indian head stuff
Old 03-08-2011, 06:34 PM
Z8'S's Avatar
All I use.
Old 03-08-2011, 06:43 PM
1994Z28Lt1's Avatar
i've used that stuff on a couple different engines and never had any problems
Old 03-09-2011, 07:01 PM
noice's Avatar
Doesn't have to be, but not a bad idea.
Old 03-09-2011, 07:28 PM
05HD's Avatar
I have had a tube that size of "GM" thread sealant for over 6 years. I still can't seem to use it all, despite having been in tons of engines and using it all the time. If you use the whole tube on one LT1 head gasket swap, stop drinking the ****!! It isn't good for you!
Old 03-10-2011, 04:37 PM
adamc's Avatar
Default no sealant
anyone put there cylinder heads on without using sealant on the head bolts. Is sealant a must?
Old 03-10-2011, 04:46 PM
djjab57's Avatar
I would use the ARP thread sealant
Spiers's Avatar
adamc -The head bolts enter water. So yes.
Old 03-10-2011, 04:48 PM
gregrob's Avatar
You don't have to ever change your oil either bit its a "good idea".
Old 03-10-2011, 08:37 PM
jaycenk's Avatar
This why I was asking... Seems when My father tried to help me out and put the heads on for me and he missed that part about the thread sealant and now it has started to leak into the Cylider some how. It's not in the oil yet but I am going to pull them off the begining of next week so I take pics of what happens when you don't use it lol.
Old 03-16-2011, 11:42 PM
robsquikz28's Avatar
Originally Posted by Z8'S
All I use.
same here
Quick Reply: What thread sealant
