Canton Oil Pan Question
Old 03-12-2011, 07:43 PM
am_muscl's Avatar
Default Canton Oil Pan Question
I just got a badass looking Canton Oil Pan from T/A LT1 but there are two holes without plugs, obviously the one being the drain plug and he said the other was the oil level sensor plug near the back of the pan.
I was wondering if I need to order a special drain plug from Canton or if I could use my stock drain plug. Also with the oil level sensor, could I just put some thread sealer on a bolt and plug that hole?
Old 03-12-2011, 08:25 PM
RamAir95TA's Avatar
You didn't get a new plug with the pan?
Don't use a bolt. I would use a gasketed plug that you can get from pretty much any parts store.
Old 03-12-2011, 08:38 PM
James Montigny's Avatar
It should have come with a nice big magnetic drain plug.
The nut on mine is 7/8".
Also, the oil level sensor is in a bad spot if you have hooker headers.
I had mine relocated
Attached Thumbnails Canton Oil Pan Question-img027.jpg   Canton Oil Pan Question-someone-elses-oil-pan.jpg
Old 03-12-2011, 09:10 PM
jaycenk's Avatar
Did you check to make sure he didn't put the plug inside the pan? I have never heard of someone selling a pan with out the drain plug. Any way for the oil level sensor it is an odd size so don't just throw anything in there. I did the research over a year ago when I was looking for a plug to plug mine. It's an odd odd bolt think it's M20 1.5 I think!!! It's been a while. No regular auto parts store carries them and gm wants 30 bucks for them. Summit sells them but again 20+ bucks. I found one at ACE for 5 bucks. Go to the nut and bolt section and find the bin with oil drain plugs since it sounds like you need one and it is in with them or usually right next to it. Might want to check on that size but I think it's right.
Old 03-12-2011, 09:18 PM
1/2"-20
http://www.google.com/search?source=...oil+pan+thread
It's a standard part for light GMC trucks. You can proably find it at the parts store.
http://www.clipsandfasteners.com/Dra...d_p/a14196.htm
Old 03-12-2011, 09:59 PM
jaycenk's Avatar
Thats the drain plug size I take it? The other the M20 1.5 is usually the oil level sensor in the side of the pan. At least I think thats the number. I know the M20 is corret but as for the pitch ?
Old 03-12-2011, 10:01 PM
Yes, sorry. I should have been more specific.
1/2-20 is the size and thread pitch of the drain plug (use a 7/8" wrench)
The stock oil level sensor fits the Canton pan.
I don't remember what wrench I used on it or what the thread pitch was.
If you look at my photos (above), you can see which is which.
Old 03-13-2011, 11:21 AM
am_muscl's Avatar
I'm positive it came with no drain plug or oil level sensor. Either way I plan on going to ACE I just wanted to see if I had to special order it from Canton. But I know for a fact ACE has those sizes.
Old 03-13-2011, 02:36 PM
jaycenk's Avatar
Yea you gota love ACE. I can't wait untill the build the one close to me. Hardware... here I come.
Old 03-13-2011, 04:54 PM
96TransAmboosted's Avatar
There is also a threaded hole that faces up on one of the kick outs on the pan. not sure what size it is or if you were even talking about it. Im using that for my return oil line from my turbo set-up im working on.
Old 03-13-2011, 06:02 PM
AChotrod's Avatar
Hmmmm you wanna make a trade for a stock pan and cam or maybe some other stuff?
Old 03-13-2011, 09:51 PM
am_muscl's Avatar
^^^ pm sent Mike
Old 03-14-2011, 12:29 PM
quik95lt1's Avatar
yea i just plugged mine yesterday for the oil level sender......canton makes a plug for it its a M20 plug.
Old 03-14-2011, 02:53 PM
Puck's Avatar
Did you use the canton plug or just a hardware store one?
I'm a cheap bastard so I'll probably just pick one up from a hardware store and throw it on with some silicone .
Old 03-14-2011, 03:03 PM
quik95lt1's Avatar
i got the one from canton......siliconed it anyway lol
Quick Reply: Canton Oil Pan Question
