Idiot gages and lights just quit working.
Old 03-25-2011, 01:50 PM
stburgpete's Avatar
Default Idiot gages and lights just quit working.
Idiot gages and lights just quit working. Then start working. Anybody have any ideas this is driving me crazy.
Old 03-25-2011, 02:30 PM
stburgpete's Avatar
Can it be the ignition switch doing this?
Old 03-25-2011, 02:34 PM
ANTICOP RAM AIR's Avatar
have you recently switched out your dash assy?
Old 03-25-2011, 02:38 PM
stburgpete's Avatar
No i have not. I only replaced the switch last Aug.
Old 03-25-2011, 02:41 PM
i know if you dont seat the dash well after you take it out, it will do that. can you make it flicker yourself, like if you jiggle the steering wheel or move anything? If they are ALL going on and off at the same time, i would say its some sort of ground. think if you have done anything to the dash other than that switch. try to control the problem and that will give you a good idea of where it is if you can. a video would be nice too.
Old 03-25-2011, 02:46 PM
stburgpete's Avatar
The only time it goes on and off is with the key turning. Not every time only when it wants to.
Old 03-25-2011, 02:49 PM
stburgpete's Avatar
It just started today. I washed her and pumped her full. Went to start her and everything started happening.
Old 03-26-2011, 12:24 AM
stburgpete's Avatar
Anybody? Ideas will help.
Old 03-26-2011, 12:39 AM
edobi21's Avatar
Sound like you got some electrical gremlins to trace.
Old 03-26-2011, 09:06 AM
stburgpete's Avatar
Tell me about it.
Old 03-26-2011, 09:49 AM
James Montigny's Avatar
Dimmer switch? :p
Old 03-26-2011, 10:41 AM
stburgpete's Avatar
Originally Posted by James Montigny
Dimmer switch? :p
Don't think that would cause every thing to just quit and then start up again but I am going to try to replace the multifunction switch (aka) ignition switch.
Old 03-26-2011, 10:59 AM
Oh I misread, sorry.
Sure sounds like the cluster is not properly seated or the wiring harness behind it is damaged.
Old 03-26-2011, 11:01 AM
stburgpete's Avatar
Hope to fine out in a min.
Old 03-26-2011, 12:54 PM
stburgpete's Avatar
Anybody know if there is a relay that turns the idiot lights and gages on when you turn the key on to start the car?
Old 03-26-2011, 04:21 PM
if it flickers when turning the key then the ignition relay is fine. i would concentrate on the ignition assy.
Old 03-26-2011, 11:13 PM
stburgpete's Avatar
ignition assy.?
Old 03-27-2011, 11:37 AM
stburgpete's Avatar
Anybody else have ideas I still have nothing so far.
Old 03-27-2011, 06:58 PM
stburgpete's Avatar
Ok how about this 1994 Z28. I am looking for all the ground wires. Can anyone help????? There has got to be more then three grounds.
Old 03-27-2011, 09:12 PM
http://shbox.com/1/battery_cable_ground.jpg
http://shbox.com/1/g103.jpg
http://shbox.com/1/coil_loc.jpg <-- on the coil stud
Quick Reply: Idiot gages and lights just quit working.
