Le1 heads and .026" head gasket what size push rod
Old 03-25-2011, 02:48 PM
henry172's Avatar
Default Le1 heads and .026" head gasket what size push rod
I am wondering what size push rod I should run with my le1 heads with ls7 lifters and the 0.026" head gasket; or do I need to measure the length?
Old 03-25-2011, 02:52 PM
katz_2003's Avatar
You need to measure with a pushrod length checker. Every application is different so id be safe and measure
Old 03-25-2011, 03:00 PM
robsquikz28's Avatar
IF not one thing has changed a 7.2 rod will be fine
Old 03-25-2011, 03:31 PM
henry172's Avatar
O.k I am going to go ahead and buy 1 lifter to turn it into a solid lifter and the comp push rod checker; I just need to sop being lazy and do it the correct way.
Old 03-25-2011, 03:50 PM
jaycenk's Avatar
I'm with rob my LE2's with same gasket came out 7.2's but I did messure to be sure.
Old 03-25-2011, 04:15 PM
James Montigny's Avatar
You really should measure to get the geometry right.
I ran 7.150" with my LE2s and a .026" gasket, but I had stock replacement lifters.
Quick Reply: Le1 heads and .026" head gasket what size push rod
