What Optispark is best???
Hey all,
I have decided to replace my optispark, since it took a crap on me a couple days ago...
Whats best?
I heard AC Delco/OEM was best, and then I was told to go MSD?
Is there really a big difference?
I also plan on Electric water pump... Will I notice a difference in power?
Thanks,
Kyle
Whats best?
Thanks,
Kyle
Here you go...
http://www.summitracing.com/parts/ACF-1104032/
MSD is not all it's cracked up to be. I'm running a Delco opti in my M6, with an MSD cap & rotor kit. I wouldn't buy the MSD cap & rotor again, though it's a decent product. Since mine is spline drive and non-vented, I wanted the venting that the MSD kit offered. Now I know how to mod my spline drive optis for venting & beefing up the rotor, so I don't need a $155.00 cap & rotor kit.
Other aftermarket optis will work. However, how long they work is still in the data gathering stage. Some folks have had good luck with various aftermarket units, many have not.
I think Im gonna go with AC Delco...
Is an electric water pump really worth it? Or should I just save the money and get a re-manufactured one?
Is there anything specific I should do when Installing the opti, so I can ensure it wont fail soon after install?
The best Optispark is one that has been removed from an Lt1 and made into a trophy
But ACDelco is what I'd use of I was still running one.
I didn't have trouble with the MSD, but it wasn't anything amazing either.
Haters be hatin
[QUOTE=SpeedFreak123;14696060]Hey all,
Whats best?
Thanks,
in my book NONE look at this http://www.gmt400.com/forum/showthre...997-K1500-SBSS
that is my cure for the OPTI issues
Whats best?
Thanks,
Hi my friend
I would like to know how its your chandler opti experience until today august 2013, i receive my performance billet unit recently to my 1994 z28 camaro, i check details of the opti very deep, my first impression its the unit use msd optical disc and lens, the cap its ok but not to close tight, i need to open and get out 1 oring than does not fit, i put the loctite blue to rotor, the rotor looks and msd, well i try to install this week but i really appreciatte your comments, i am at southamerica and believe me i don't want make any return, thanks
Can you elaborate on why the MSD never gave you any problems but wasnt amazing? I mean what defines a great opti from a normal one? Lol I wouldnt expect any performance gains from an MSD vs an AC Delco or Delphi one. Just reliability.
You can buy opti parts seperatly at parts stores...And its the best bang for the buck imo. (I've put some together for under $200) Even a %100 new unit can poop out after some miles.
I run the delphi opti unit and an old accel cap and rotor,vin P.
24x kits can be put together for under $600 if you shop around enough.
Forgot to mention the msd units often have signal issues and not worth $500.
Just my 2 copper.
Just my 2 copper.
