LT1 Ghost...I Guess.....
it seems like everytime i fix something on my car something else ***** up lol.
what would make my 96 z28 o2's read like .02volts and not fluctuate and have my short term fuel trim at 9.3percent on both banks.long term at 0. i installed new o2's again and reset the pcm but its still the same. my map is at 70kpa maf at 10. the car is thinking its lean and loading up with fuel.i have absolutely no exhaust leaks...and this is something that just started since i got it back running...but its been down about 3 weeks
i was about to my my guage is missing the fitting that i need..need to find it.
question...there has been times where my pump primed for a long time when i cut the key on.like for 15 seconds or so ...and other times its normal like 5 seconds or so.does that sound abnormal
k..finally found my fitting and checked pressure,,it has about 40psi at idle with vacuum. when i remove vacuum it jumps to about 45psi.and at idle the engine is kind of stumbling.i pulled about 4 of my plugs ...still look new.so as of now it seems that im not getting enough fuel yet i have good pressure.not black and fouled like i was thinking they would be. i replace the fuel filter about a week before my opti died
i bought only 1 extension on passenger side.but its both banks reading funky.so its something up front goin on.the car acts like it wants to stall or hunt idle.have to feather pedal to keep it from shutting down
thanks to the 3 guys that did decide to chime in.i ended up askin the guy that tuned my pcm what to look for and he nailed it first try....vacuum leak.the vacuum port under the brake booster line on the manifold had come uncapped and has been causing all kinds of trouble...shout out to Solomon......
