Lt-4 Hotcam on stock tune question
Old 04-17-2011, 11:20 PM
96Formula6spd's Avatar
Default Lt-4 Hotcam on stock tune question
Hey guys I had been hunting down my closed loop problem. Anyways I ended up swapping from my obd2 tuned computer to my stock tune obd1 with emissions deleted. Anyways the car now runs like a champ. So since the car is a 100 miles away at my parents house would it be ok to drive the car untuned for a while. I am going to get the car dyno tuned in the next few weeks. Do you think it will be ok on the stock tune say for 1000 miles?
Old 04-18-2011, 12:26 AM
munsterz28's Avatar
i have been driving my lt4 hot cam car untuned for 2 years now i think youll be just fine.
Old 04-18-2011, 04:49 AM
RamAir95TA's Avatar
Don't expect to set any land speed records with it. Tuning is EVERYTHING!
Old 04-18-2011, 05:48 AM
Rob
Rob's Avatar
When I did the HOT cam in '98, I ran the stock computer. It was fine for driving but mine set the light for misfire all the time. It also ran INCREDIBLY lean at WOT. It would buck like crazy even on the dyno, nice saw tooth curves. Since there was no tuning for OBDII back then, I went with a OBDI computer.
You should be fine with the stock computer in normal driving.
Old 04-18-2011, 06:20 AM
moehorsepower's Avatar
Default Hot Cam
I just tuned a 96 with the LT4 Hot cam kit and on the stock tune it was rich, Not super rich, 12.2 average so it wont hurt, but like said, Tuning is everything, after the dyno tune he gained 18 RWHP, Not a whole lot, but if you do a mod, tune it to get the max benefits out of it. Another car installed a cam in the 224 duration range and he gained 36 RWHP, even though on the stock tune it idled ok and he said it ran fine.
Old 04-18-2011, 11:34 AM
GREGG 97Z's Avatar
Why even bother installing a cam if you're not going to get it tuned???
Contact pcmforless and get it tuned correctly, you will be amazed at the difference it will make.
Old 04-18-2011, 11:47 AM
Sounds good. I know its not going be fast but its the first time the car has run right in 26 months so I am very happy. The car will be getting a 383 down the road. Maybe with a turbo.
Quick Reply: Lt-4 Hotcam on stock tune question
