95 lt1 starts, runs for 3 secs and dies ??
Hey guys, im new to the forum i and have an 80 trans am that i swapped a 95 lt1 into, it was running fine last week, now its runs for 2 or 3 secs then dies. The only thing i did to the car since it was running was unplug the pcm without disconnecting the battery, and i noticed the plug on the coil was off while i was cranking it over. I thought the plug was the problem but it wasnt. Do you guys think i coulda screwed the computer up??? Is there a way to tell?? I know its not the vats system already for sure. Your help is appreciated, great forum by the way!
its not vats, i bypassed it with a resistor, 237 ohms actually, i did it when the engine was in the donor car so i know it worked and i replaced the resistor with a new one just in case. its bypassed permanantly, i used to do remote starters so i have tons of experience bypassing them.
i only disconnected the batt for a few secs, i'l disco it for 30 mins, maybe il get lucky
you can keep the ideas coming....
what are the odds that i wiped out the computer??? hope i didnt....
Well i discoed the batt for an hour stil the same thing ??? I dont have the aldl connecter wired in yet ( still tryin to find a diagram ) i did however check the fuel pump wire with a test light, it stayed lit the whole time. Ive used resistors before and they always worked, i just measured the chip on the key and matched it with one of the 15 (?) possible resistors.
Maybe il search on here about that 50 hz bypass module, i never heard of that??
Until then any other suggestions??
It kills the injector signal. Wiring the pump on won't help. Odd that all the experience you say you have with VATS and don't know about the fuel enable signal. That's half of what VATS does.
Is your intake all hooked up, as in maf connected to the intake or is it plugged in but not connected to the intake? If your maf is plugged in and not connected to the intake it will do the same as what you have also.
well its only a couple years old, its an external mount that i bought from summit, its only been turned on maybe 20 times. this is a project car that i havent even driven yet. fuel pressure seems good at the regulator, the run/turn off time is extremely consistent, so idk??? im thinkin to just send the computer out to somebody to check it, it needs to be tuned for a lil more performance anyways i guess since theres headers, no emissions, no ac, remove vats etc...like i said idk, this is frustrating
UPDATE, ITS FIXED!! I WAS DOING PIN OUTS FROM LT1 SWAP.COM ( EXCELLENT SITE BTW) AND ONE OF THE WIRES LISTED AS NOT NEEDED WAS THE BLUE FUEL ENABLE WIRE #29 I BELIEVE. I GUESS HE LISTED THIS WIRE FOR THE GUYS WHO HAVE THE VATS SYSTEM TURNED OFF IN THE COMPUTER, ADD A 6 PACK OF CORONAS TO THE MIX AND WELL........THANKS FOR THE HELP GUYS IT PROMPTED ME TO REALLY DIG IN TO THE VATS SYSTEM AND GO OVER EVERYTHING I DID, SO THANKS AGAIN!! NOW ITS OFF TO THE SPRAY BOOTH YAAYYYY!!!!
... I know its not the vats system already for sure...
Millsmotorvation, thanks, oh dont worry ive been keepin an ey on you . I had an 81 pace car about 15 years ago and loved it, never should've sold it. I read your thread and i'm watching, i wana turbo mine someday too, but right now i gota get some paint on it and some miles too! Had the car for 4 years now and have never driven it.... I really wanted to do a G.N. turbo motor but theyre a lil pricey and well the lt1 was free
