Starter access with Long tubes. Ebay and Pacesetter
Can anyone access there starter with longtubes. I have pacesetter L/Ts and a set of Speed Daddys Kooks headers. I'm in the middle of installing the ebay headers and there is no starter access. I cant even see the one inside starter bolt.
If I need to remove the starter I have to pull the passenger side header.
Are the Pacesetter long tubes going to give more access. They look alot longer then the ebay headers so I was thinking they might merge past the starter ?
What headers would you run if you had both to choose from.
ive had 3 sets of pacesetters, never had a clearance problem with anything at all. i dont even have to lift the motor to install the last set i put on. On a side note ive installed 2 sets of ebay headers both were close to the starter and oil filter making them a lil harder to remove.
[QUOTE=badass383formula96;14983049]ive had 3 sets of pacesetters, never had a clearance problem with anything at all. i dont even have to lift the motor to install the last set i put on. On a side note ive installed 2 sets of ebay headers both were close to the starter and oil filter making them a lil harder to remove.[/QUOTE
Have you ever had a starter go bad because the header sits so close.
I dont think its that big of a deal that I don't have easy access to the starter as long as its not going to kill it. I have had no reason to remove my starter in the past.
