Looking for review of my LT1 383 Build
Below is my current idea for my 383 Build. I currently have a 1996 Z28 M6 with about 170k miles. I have not done any modifications, and the last owner put 4.11 gears in. My power goals are to be around 430rwhp/rwtq.
Clayton Racing 383 Shortblock $1700
TFS 21* 195 Heads $1500
Ported Stock Manifold $200
219/227 .575/.575 VooDoo Lunati Cam $300
Delphi OptiSpark, New Plugs/Wire $500
Pacesetter Full Length Headers/ORY $500
1.6 Ratio Scorpion Full Roller Rockers $250
LS7 Lifters $125
Trickflow Chromemoly pushrods $100
Misc other parts to install $1000
I figure I am in the 6-7 thousand range.
I already have the parts to do a LS1 Lid conversion and I am also considering a Coil conversion. I figure this build will blow up my 10bolt, so I am looking in to an 8.8 build.
I plan on doing all install and assembly work myself and am looking for suggestion on what to change to make the build better overall, without increasing the build cost.
LS7 Lifters $125
LS7 Lifters $125
LS7 Lifters $125
You would save money on buying a ported stocker package from LE or AI instead of paying 1500 for heads then 300 for cam, but then you wouldn't have as many upgrade options. Both companies can get you 430rwhp through a 6-speed pretty easily.
Or, you can keep those heads and just get a healthier cam, and later on if you want more power you can have the TFS heads ported and change the cam for some even bigger numbers.
LS7 Lifters $125
LS7 Lifters $125
Cam is too small for sure, and honestly, so is your overall budget. You'll need to tack on at LEAST another $1000 for other miscellaneous things like gaskets, tuning, intangibles, etc. What crank in that Clayton shortblock?
Or you could just spend 3k more and buy my entire car (sorry, had to plug ).
As cast heads and a baby cam, your recipe and goal are not anywhere near the same page.
Those are quality heads and I am sure the cam is a nice piece for a mild stock displacement motor.
I could not get their site to work well but they have a cast Scat crank shortblock on ebay starting at $1995. A forged Scat rotating assembly for $1700 but then you need to add machining, balancing etc plus a block to put it in.
Regarding the Shortblock, it is the Scat Cast setup with forged rods/pistons. I know the Scat Cast Crank is not popular around here, but I have been told by multiple engine builders it is fine up to 500hp, which my build may only barely reach.
I favored those heads over ported stockers because they have more room to grow. But as my Shortblock cant handle any more than ported stockers could put out anyways it does not seem to make much sense to shell out extra for them.
Bigger injectors (39/42lbs), a 255gph fuel pump, and 58mm TB are all on my list to get, I just forgot to add them in my original post. Also, I know a catback it a good idea, but I actually really like the sound of the stock one. So I know I should get one, I'm just not committed to it.
With the camshaft, would I want to be more in the 23x/24x range with 60x lift to get up to the 430+ range? My restrictions with cam are two: 1) I have to be able to run A/C well as I'm in AZ and this is my DD, and 2) I dont want to sacrifice a lot of low end torque for high end hp. If I cant make my goal without losing low end torque I will have to lower it to something more reasonable.
Thanks for all the quick replies. What would be the correct forum here to discuss the merits of this build vs. a 6.0 L92 swap?
You expect 430whp which is well in excess of 500fwhp, so what makes you (and your engine builders) assume that a cast crank rated at 500HP would handle it? If that's your goal here then you will need to go forged, period.
You don't give ported stockers enough credit. I have the AI 200cc ported stock castings on my car, a cam similar to your suggested second post specs (23x, 24x), and put down the numbers in my signature. Ported stock castings from AI have sustained power levels regularly pushing cars into the single digits.
Having been there, done that, along with several other of the guys on this forum I would revise your crankshaft and valvetrain decisions.
Some things don't add up here.
I must be misinformed, as I thought that 500 crank horsepower calculates to about 425 rear wheel horse power.
If I redefine my power goal as 500 Crank horsepower (to be safe with the cast crank), what would be a solid setup to get me there? An LE1 Package with an appropriate cam? or is that going too small? I have never modded LT1's, so I'm just trying to learn as much as I can from you guys.
