Tired of feeling body roll everytime I turn a corner at high speeds..
Personl thing.. I often like to roll around a corner an then just gas out of it breaking the tires loose.. When I do it I sometimes feel a nasty body roll n the car that just makes it feel like the car is going to tip over lol.. I was told stiff shocks would solve this problem?
I'm running the older Bilstein HD's on stock springs, Strano front and rear sway bar, SLP subframe connectors, car feels great, I don't notice any body roll. Other suspension stuff I'm running is Spohn torque arm(UMI relocation mount), lcas and panhard but I don't know if any of that would really influence that.
Screw the corvette...you need 35mm/25mm front/rear SOLID swaybars (with poly bushings) and some lowering springs....I put swaybars on my car recently and the difference is dramatic. No body roll whatsoever, it's like a 3400lb go-cart now I can take curves 5-10 MPH faster now. It makes my 99 Firehawk with level II SLP suspension feel like a soft *** Buick; if I try to do the same **** in it as my 94 Formula, body roll, screeching tires, scariness....not so with the big roll bars as you get a LOT more feedback from the road and eliminate body roll completely. It's definitely one of the most fun mods out there and underrated if you ask me. (They do weigh a good 20 lbs more than stock however).
i like the koni shocks with the hotchkis springs and brm sway bar kit, bmr subframe connectors and the bmr tunnel brace with strut tower brace, the strut tower brace stiffins the front very nice for carving corners.
I have about 160k on the motor.. Possibly could change my bushings to help as well.. BUT When u say shocks and springs I want to go twards the stiffer 1s right?
Thanks for the info bro. How much did you lower your car? I really didn't want to mess with the hight of the car due to the LT headers I'll b installing and due to the high rugged speedbumps around my city.. But if it's necessary to fix the body roll completely then I'm all for it.
They are also solid where the factory ones are hollow.
