corrosion: harness n opti
The car was throwing a couple codes n notice it rare occasions the car wouldn't start. If it did after a minute of sitting it would idle kinda funny. Pull of the opti harness and see corrosion . Then after that I seen that the inlet where the harness connects to the opti had corrosion as well. Here some pics...
You also might want to check the vent line when you put it back together. I went through 2 opti"s with the harness doing the same thing. My vent line was cracked where it connects to the intake manifold.
