What mild cam for a street/sometimes strip car.
Old 07-05-2011, 08:33 PM
"I MAID THEESE"
Mavn's Avatar
Default What mild cam for a street/sometimes strip car.
I have a 1996 camaro z with cai, intake elbow, pacesetter long tubes, highflow cat, cutout, and nitto 555 tires.
I am wanting a really high 12 or a really low 13 car. I am going to be getting a matching stall with my cam. I can get a hotcam kit for $400, But I don't want a hotcam.
So I'm leaning toward a cc503, but need help deciding. Somebody reccommended me this: http://www.jegs.com/i/Comp%20Cams/249/07-466-8/10002/-1?CT=999
So, if you have a cammed lt1 and are liking the power, let me know! I like alot of low and midrange power. I know there are other choices and are looking for advice. I don't want to do an le setup because I don't have enough money to upgrade my rear and tranny. It's a 4l60e btw.
Thanks!
MaVN
Old 07-05-2011, 08:37 PM
Wicked94Z's Avatar
what kinda converter are you running? You can make more torque than stock and still gain 30hp more up top, just depends where you want the peaks to occur.
Old 07-05-2011, 08:39 PM
"I MAID THEESE"
Mavn's Avatar
I don't have a converter yet. I'm waiting on my cam.
Old 07-05-2011, 08:42 PM
Wicked94Z's Avatar
What kind of budget are you working with?
Old 07-05-2011, 08:45 PM
"I MAID THEESE"
Mavn's Avatar
I don't want to spend over $700 for the cam, springs, rr, pushrods. Etc..
Old 07-05-2011, 09:04 PM
whytryz28's Avatar
Good luck, buy used parts you could do it.
Old 07-05-2011, 09:05 PM
Wicked94Z's Avatar
i'd look at getting an edge converter. with filter, fluid and cooler you'll be around 700 bucks.
Old 07-05-2011, 09:06 PM
"I MAID THEESE"
Mavn's Avatar
That's just what I want to spend on the cam stuff. I'll spend another 600-800 on the converter. Any ideas on what cam?
Old 07-05-2011, 09:32 PM
RamAir95TA's Avatar
With that budget you aren't leaving yourself enough $$$ for the NECESSARY parts. A cam swap is an easy $900+ with tuning done properly.
Read the cam sticky at the top of the forum. Lots of good info.
Old 07-05-2011, 10:41 PM
happysem's Avatar
Goals are easy to hit for a stalled/cammed car.
You could probably hit those goals stall only.
With that budget and low goals, you could grab a hot cam kit from like Summit or something ($600ish, but doesn't quite come with everything)
Also, like it was said - you will need tuning.
Go with a popular setup and you can get a cheaper mailorder tune (under $200) compared to dyno tuning with a custom setup.
Old 07-05-2011, 11:16 PM
"I MAID THEESE"
Mavn's Avatar
What is missing in the hotcam kit?
Old 07-06-2011, 01:33 AM
LSWHO's Avatar
A cam is overkill for your goals. Bolt ons and traction in decent air is all you need.
The hot cam is probably the only way in your budget to cam it.
Luckily for you, the hot cam will help you surpass your goal performance wise.
In other words, get the hot cam.
Old 07-06-2011, 01:48 AM
"I MAID THEESE"
Mavn's Avatar
Sweet. So stall, boltons, and hotcam should get me into the 12s?
Old 07-06-2011, 05:44 AM
gregrob's Avatar
No, bolt ons will get you into the 12s at sea level ish. Font waste your money on a cam until you have all the supporting mods.
Old 07-06-2011, 11:38 AM
irocurpony8489's Avatar
i agree i have no idea what the elevation is at my track Maryland internatinal race way, my mods are in my signature i ran a 12.75 @ 105 1.68 60 with a 191k ragged out motor.
Old 07-06-2011, 11:54 AM
"I MAID THEESE"
Mavn's Avatar
My goal for high 12s was so I can stay with stock ls1s and ls3 maros. They run high 12s, right?
Old 07-06-2011, 12:24 PM
quik95lt1's Avatar
advancedinduction.com
•Ai 226 / 234 - .569/.570 - 110 LSA - Primary Operating Range: 2000 - 6200 rpm
◦This is our largest stock long-block cam for auto cars. Lopey idle, good drivability, and excellent mid-range with peak power at approximately 6200 rpm. Properly tuned w/ supporting modifications, M6's typically produce 345 - 360 rwhp SAE corrected.
use that cam.......
•Ai 218 / 226 - .540/.540 - 112 LSA - Primary Operating Range: 1800 - 6000 rpm
◦This is our version of the venerable LT4 Hotcam. Noticable idle, good drivability, and strong mid-range with peak power at approximately 6000 rpm. Properly tuned w/ supporting modifications, M6's typically produce 335 - 345 rwhp SAE corrected.
or this one if you want to go a bit less radical
Old 07-06-2011, 12:38 PM
TheHeadFL's Avatar
I run a XE 224/230 and I daily drove it for 2 years with no problems. Good power. (I think it is the CC503 now?)
That is what I'd go with.
Old 07-06-2011, 12:48 PM
happysem's Avatar
Summit's LT4 Hot Cam Kit is like $650 and comes with cam, springs, rockers, etc.
You should still get things like pushrods, timing chain, lifters, tune, gaskets, etc.
So its a bit cheaper, but not sure about quality of the parts.
By the way, specs on the cam are 218/228 .525/.525 112 lsa.
Not gonna post the link, but you can find it on summit pretty easily, or just PM me for link.
Old 07-06-2011, 12:56 PM
96lt1m6's Avatar
LPE 211/219
As stated prior bolt ons w/3600 stall will put you in the 12s in good air.
Adding a cam like i mentioned will defininately get you into the 12s with good tires/traction of course
Quick Reply: What mild cam for a street/sometimes strip car.
