car is cutting out at 3k rpm
so the car says low battery voltage and when you take off the car cuts out and starts studdering at 3k rpm, so you cant take it past 3k rpm. im thinkin maybe a coil but does anyone have any other suggestions?
If the car has low voltage, of course the coil wont fire properly. Checking the coil is a waste of time. Fix your low voltage issue. A coil won't charge and fire properly without the voltage it needs.
Always fix the known problem before trying to diagnose and throw parts at a secondary problem. One of the biggest rules of being a mechanic.
