Coolant Cross over tube
Old 08-29-2011, 10:35 AM
Whyrun's Avatar
Default Coolant Cross over tube
Has anyone come up with a better way of hooking a coolant crossover tube? I was putting everything back together saturday, when I got to this point. It seems like the bolts on the factory piece don't fit very well. I was afraid the threads would strip out on the heads before the bolts became tight. So this made me wonder if I should just use a couple of 90 degree An fitting of some size, with a T fitting and run it back to the radiator. If anyone has tried this let me know, pics would be good to. Thanks
Old 08-29-2011, 10:42 AM
RamAir95TA's Avatar
It is very common nowadays to substitute the steam tube for -AN fittings. Do a search for "Coolant Crossover AN Conversion." Pretty sure there are several (lengthy) threads about it.
Old 08-29-2011, 10:55 AM
Whyrun's Avatar
Funny, I did a search and pulled nothing but threads about LS crossover related stuff. I should have search cross over conversion instead. :d
Old 08-29-2011, 10:57 AM
whytryz28's Avatar
If you want to save money, head to Home Depot and get brass fittings and rubber hose and clamps.
Old 08-29-2011, 12:47 PM
Gojira94's Avatar
Just what I did on a recent project... not really pretty but very stout. High temp thread sealer used here. Careful with aluminum if you go that route. Not a huge problem, but galling can occur when you twist aluminum into aluminum.
Attached Thumbnails Coolant Cross over tube-274426d1295154963-rescued-wounded-bird-p1501110000.jpg
Old 08-29-2011, 01:10 PM
Village Troll
SS RRR's Avatar
In the case of making a cross over and not being all too visable, form < function.
Old 08-29-2011, 01:58 PM
whytryz28's Avatar
Basically, no way would I pay anything close to AN fittings.
Old 08-29-2011, 10:42 PM
z_speedfreak's Avatar
advanced search is your friend limit your search to this sectionand bam https://ls1tech.com/forums/lt1-lt4-m...-pictures.html ..I had this one bookmarked tho
Quick Reply: Coolant Cross over tube
