can I use 1.6 rockers under stock valve covers
Old 09-02-2011, 05:18 PM
blog78's Avatar
Default can I use 1.6 rockers under stock valve covers
I have mixed opinions on what rocker to use!! I want to use 1.6 rollers but I keep gettin told they wont fit under the stock valve covers. I've been told that 1.5 rollers won't work as well. There is a very small market for after market v covers and if you do get taller v covers then there is an issue with the alt and alt bracket clearance... And if I can use the 1.6s what length does the push rod gotta be?
Thanks
Old 09-02-2011, 05:21 PM
96TransAmboosted's Avatar
Yes. Both will work with no issues. I run comp 1.6 stock cover with no issues
Old 09-02-2011, 05:42 PM
BALLSS's Avatar
Crane "narrow body" RR will fit with no alterations
Others require simple triming of the brace inside the VC
scroll to bottom of link for 411 on VC trim
http://www.golenengineservice.com/lt...r-lt1-engines/
Old 09-02-2011, 05:53 PM
whytryz28's Avatar
Depends on the brand, some fit, some don't without trimming.
Mine fit without trimming.
Old 09-02-2011, 06:12 PM
defaultexistence's Avatar
Push rod lenght won't change
Old 09-02-2011, 06:22 PM
Rob94hawk's Avatar
How about 1.6 COMP Cams Ultra Pro Magnum Rockers?
Old 09-02-2011, 07:23 PM
pdx94z28's Avatar
Scorpion narrow body 1.6's fit like a dream.
Old 09-02-2011, 07:33 PM
Wicked94z28's Avatar
Buddy got some 1.6 rrs from comp that look similar to stockos and they fit with stock valve covers with no trimming..... me on the other hand.got crane golds and had to grab Canton tall covers which look badass imo
Old 09-02-2011, 08:32 PM
spcearle's Avatar
Ive had crane golds for years with no modding needed with stock covers... Now I run egay polished covers with still no clearance issues
Old 09-03-2011, 11:10 AM
FAD2BLK93's Avatar
I run the lt4 rollers with no issues for years...push rod length will stay the same.
Old 09-03-2011, 11:17 AM
Village Troll
SS RRR's Avatar
Taller adjusting nuts?
I am running the Gold Racing series rockers under stock valve covers...
Old 09-03-2011, 11:39 AM
shbox's Avatar
Vc's will need trimming. See the Golen link in post #3.
Old 09-03-2011, 11:43 AM
Village Troll
SS RRR's Avatar
If you want to keep all the rigidity of the valve cover all you have to do is bend the lip of the cross brace down. That is the only part of the VC that gets in the way of the rocker trunions.
Old 09-03-2011, 12:16 PM
Rob94hawk's Avatar
Thanx.
Old 09-03-2011, 03:01 PM
blog78's Avatar
Thank you for all the info it has helped. This forum is awesome wish I would have been here since 2003 when I bought my 02 Z28 could have used alot of this info a long time ago.
Old 09-04-2011, 01:17 PM
blog78's Avatar
This was perfect examle of what to do thanks now I can put the rr back in my budget!! I am goin to use the lt4 hot cam and 1.6 rr can I use the stock push rods??
Old 09-04-2011, 02:30 PM
Camaro_ZL2's Avatar
you can but ive herd some people ended up breaking theres better off getting some harder ones if your going with a bigger cam
Old 09-04-2011, 02:44 PM
boostedlt1's Avatar
yeah get hardened ones, they're cheap insurance for $30-40
im running the crane gm lt4 rockers with no issues
Quick Reply: can I use 1.6 rockers under stock valve covers
