will lt1 rack an pinion fit on ls1?
my 99 T/A is leaking fluid like a **** out of the rack and steering box. my buddy has a totaled 94 Z28 that has a good rack. will this swap right over? and is it the exact same thing?
They will definitely both interchange like said but not sure if the LT1 rack clears the LS1 accessories or manifolds... LS1 is angeled out towards the outside of the car more than LT1. If you do try the LT1 rack you also need to use the steering shaft from that rack which is a downgrade from the nice LS1 piece. All in all the LS1 rack and shaft are a nicer unit to have, shaft is better, rack helped with clearance for headers etc..
he can still use the ls1 rack with the lt1, his steering wheel will be clocked wrong. You won't be able to get it straight with the rack and have equal turn to turn.
You can reindex the ls1 input shaft to make it work with lt1 rack. It's a better upgrade over the lt1 even with the rag joint eliminator.
