Converting 95 TA auto to 6spd. Harness,ECU needed?
Old 09-06-2011, 01:35 PM
986.0333hp's Avatar
Default Converting 95 TA auto to 6spd. Harness,ECU needed?
I'm going to convert my 95 TA to a 6spd but I need to know if the ecu and engine harness are the same. The parts car is a 97 Camaro Z28. Thanks
Old 09-06-2011, 06:47 PM
986.0333hp's Avatar
Any one have some experience with this conversion?
Old 09-07-2011, 05:44 AM
The Batman's Avatar
I did it in a weekend pretty much by myself. You can use your stock harness and computer, you have to change some pigtails to plug the trans in. Also you're gonna need to Reflash your computer.
Old 09-07-2011, 06:12 AM
RamAir95TA's Avatar
You can use all the same stuff. You shouldn't have to rewire anything, just tuck the A4 harness connector out of the way.
You don't HAVE to reflash the computer because the car will drive just fine - you'd just get trans codes (which if you wanted you could have programmed out).
Old 09-07-2011, 12:54 PM
986.0333hp's Avatar
I also have the 6spd computer, so I can just swap it in as well or will the mileag be thrown off?
Soit will drive fine but will it set off the check engine light (trouble codes)? Thanks
Old 09-08-2011, 03:54 AM
The Batman's Avatar
If you don't Reflash the computer, you will notice one bug flaw... Your speedometer will be wayyyyyyy off. I drove mine until my mail order tune arrived and when I was driving about 55mph it said 150mph lol. Not sure about swapping to a different computer tho.
Old 09-08-2011, 05:25 AM
EliteCamaro94's Avatar
didnt someone do a very descriptive write up on the swap? im also contemplating doing this swap.
Old 09-09-2011, 04:18 AM
The Batman's Avatar
Yes, if I was in my old computer i would have the link saved. If you search you should be able to find it
Old 09-09-2011, 09:35 AM
CamaroZGuy's Avatar
GMHTP has a good wright up but it was dont with a 98+ so some things may be a little different.
http://www.gmhightechperformance.com.../photo_01.html
Old 09-09-2011, 11:32 AM
986.0333hp's Avatar
Excellent! Now I have some ammo for the swap. Thanks
Old 09-09-2011, 02:06 PM
The Batman's Avatar
this is the link i used, it was damn near perfectly laid out for someone to do step by step.
***just remember to put the clutch and bellhousing on the motor than bolt the transmission to that***
http://www.afrashteh.com/tranny_pics/T56.htm
Old 09-09-2011, 03:56 PM
Formula383's Avatar
I followed the exact link when I did my swap. Added a few wires for the starter switch, reverse lockout and reverse lights and tucked the 4L60 plug up with the rest of the factory harness.
Old 09-10-2011, 10:49 AM
madhatter's Avatar
It is very easy, all the wires you need are in the harness. The computer will need to be flashed, or you can just get a 94-95 M6 computer and there will be no issues. Mileage is stored in the cluster anyways. I did mine in a day. The hardest part was the pedals and drilling a hole for the master.
Quick Reply: Converting 95 TA auto to 6spd. Harness,ECU needed?
