Oil cooler delete: what did you use to plug off radiator?
Old 09-07-2011, 12:28 PM
Rob94hawk's Avatar
Default Oil cooler delete: what did you use to plug off radiator?
For the oil cooler delete I'm Going to take the water pump to my machine shop and have them pull the lower right tube and plug it.
But what should I use for the radiator inlet? What do you guys recommend to plug this? Thanx
Old 09-07-2011, 12:40 PM
RamAir95TA's Avatar
You could just install the oil cooler bypass hose found on every non-KC4 LT1. Or a rubber plug + clamp would work too.
Old 09-07-2011, 12:44 PM
Prorac1's Avatar
I used a rubber plug and a clamp as well. But on the water pump I tapped and plugged the hole myself. It really cleans up that area down there getting the hoses out of there. Eric L
Old 09-07-2011, 01:12 PM
Rob94hawk's Avatar
Thanx.
If I may ask or if you remember, what size tap and plug did you use?
Off to ACE, again......
Old 09-07-2011, 02:51 PM
FormulaJoe's Avatar
What I did is pulled the hose nozzle out of the water pump and tapped a freeze plug in there. Then I used a regular rubber hose plug in the nozzle from the radiator.
Old 09-07-2011, 03:25 PM
95 TA - The Beast's Avatar
Just use the bypass hose... I have had rubber plugs get brittle and leak over time...
Old 09-07-2011, 05:07 PM
TWS
TWS's Avatar
I got a length of heater hose from the parts store and ran it from the water pump to the radiator.
Old 09-07-2011, 05:12 PM
jlpz's Avatar
I used the Gates 18959 hose from O'reilys makes it look more original than just capping it off..
Quick Reply: Oil cooler delete: what did you use to plug off radiator?
