Oil pressure
Oil pressure
Well got my car run after cam swap and heads by now most of u know my setup well I only have about 16 lbs at idle and when I'm on the gas I have 5 or I had to replace my sending unit cause I broke the one on it I read other treads and they said it did it to there car also but y or what would make me loose oil pressure when I'm on the gas Bad sending unit or what
Did you look at the cam bearings when you installed the cam? Did you use camshaft lube on the entire camshaft? Seems to me you need to do proper diag with a gauge like someone has already suggested. If you do have that low of pressure on start up you might not want to rev it up or let it run very long till you figure out why. I have 2 great lt1 engines with great oil pressure if you end up looking for one.
I had some what same problem during my cam swap. Start up ran 40psi then once warm running temp it dropped to 15 or so. I did the mannual gauge and it read 35-40psi all the time. Trouble shoot your gauge first like stated.. A gauge can be picked up for 20 bucks for testing purpose. Good luck man.
Note my engine was stock with bolt ons and 143,000 miles..lol
your check gauges light is coming on because you dont have any oil pressure!! and if you don't have any oil pressure the resistance from metal on metal of all your internal parts is whats making it want to stall
honestly... you've probably already done a lot of damage if you're reving it up without oil pressure. check and see how metallic your oil is
