Anyone make 2inch headers
Hey guys i will be installing a gen 1 427ci Small block in my camaro very soon. And need to find a set of headers that will fit the car but they need to be 2inch and the biggest i can find is 1 3/4.
do they make 2inch headers for our cars?
i run the 1 7/8" headmans on my car.........3.5" collector........that must be one stout 427 to need 2" headers ............with the headdmans be prepared to do modifications to #5 tube to get the plug in and also to reroute the #1 tube around the steering shaft.......
That's MISTER MODERATOR
The merge design is important. The shorter the merge is, the less efficient it is. Contact Kooks or ARH, their merges are great. As they make their stuff here, they can make you anything you want. OBX and Stainless use short merges and OBX is an Asian import so forget about anything custom from them.
Lemons will do it, but it is NOT cheap. I talked to him about doing this very thing for me and I still have the quote somewhere. I think it was around 1200 for uncoated, mild steel headers...
Here is some info he sent me on them at the time:
LEMONS HEADERS INC.
’93-’02 CAMARO SMALL BLOCK RACE HEADER
PART # SBR-120
Header Spec’s:
This header is designed for any tube size up to 2 ¼” with any collector size up to 4” or our collector muffler up to a 5” size. All of the tubes are inside the frame with good ground clearance and spark plug access. It will fit any mini starter a full size GM starter will not fit. This design will fit side motor mounts or motor plates. The passenger side is the most restrictive. Depending on the tube size you may have to slightly trim the bottom of the mid plate and the outside corner of the starter aluminum mounting block. Measuring from the side of a stock oil pan on the passenger side we have 3 ¼” of room for an oil sump kick out and on the driver side we have 2 ½” at mid pan and 3 ½” of room at the bottom of the pan. If there is no kick out on the driver side the oil filter is accessible. If you are using a Lakewood style scatter shield you may have to trim the outer edge of it below the starter area. The driver side header is close to the steering column, depending on the tube size you may have to replace the factory rag joint with a smaller “U” joint. The header will fit a hydraulic clutch system only, but is not intended for air conditioning or column shifter linkage.
NOTE: the ’98 to’02 cars used a different rack and pinion which moves the front of the steering column outward and will interfere with the front tubes on the driver side. Requires using the earlier style rack.
Installing the headers:
We build our race headers with individual tubes and a slip on collector for easier installation. Depending on tube size and oil pan kick outs you may have to remove the starter and steering column section between the 2 “U” joints.
Install both sides from front to back. As you install each tube only start the header bolts leaving them loose enough that the tubes can move freely. Once all the tubes are in snug the header bolts, but don’t tighten them until the collectors are installed then go back and tighten all the bolts.
Refer to our header installation tip’s page for additional instructions.
Thank you for selecting Lemons Headers!
If you have any questions give us a call at 805-239-8998
Dan Lemons
PART # SBR-120
Header Spec’s:
Dan Lemons
