advice need
advice need
so im putting my LT headers on. the driverside went in great, even went in from the top. now on the passingerside, i went to romove the dipstick and the housing broke off in the oil pan. i dont want to drop the pan, so does anyone have any advice? i even thought about just not putting it back on, i change my oil about 1500 to 2000 miles anyway and the car sits most of the time.
I would fix it. Your car may run fine now. But you never know when u need to check your oil. It may start burning oil or leaking and you need to know how much you've lost. It's just a critical piece of proper engine diagnostics. A place you don't want to skimp.
The tube is flared how did it break off into the pan? Get a flat head screw driver and push any lip there maybe into the center and then grab it sideways with a set of vise grips. Use the block as leverage and it should pop right out. Or if it broke after the flare and is now flush with the block get a punch and push it into the pan then fish it out with a hanger or magnet.
