Coolant leak behind motor
1 Post
I assume this is the intake gasket? I dropped the transmission on my car to fix the clutch (ty spec), and i noticed coolant in my bell housing. finally found where my coolant was going... Is this a common problem on our cars? I thought it was but I don't see anything after a few searchs. Thanks!
1 Post
hahaha awesome. now I know what to look for back there!
Can those be easily accessed without removing anything? I just want to know how much time I need to allot myself on friday.
Also, what are the O rings i need there?
I replaced my whole steam pipe set up with fittings and some hosing, its actually a little smaller then it needs to be due to my mistake in sizes but no leaks and still works like i charm, i beliece i either used some teflon tape or rtv to sal up the fittings, i'm leaning more towards i used rtv
If the steam pipe is leaking, the coolant generally runs down the outside of the transmission bell housing. If you have coolant actually INSIDE the bell housing ..... it's usually one of the rear welch plugs that's leaking.
1 Post
The coolant is visible on the slave cylinder, and it is wet up on the outside of the bell housing. the car sat without a transmission for a long time, so it probably ran down from the steam pipe. I had the trans out and the freeze plugs were dry
Good to know! Four (4) new steam pipe seals like Shoebox has shown you above, and ........ you should be ...... good to go!
1 Post
I am excited. The car has been a decoration in the driveway for almost 2 years. It is almost back up to speed... minus the tree damage from sandy on the headlight/fender
Thanks for the info!
