idle drops when pressing clutch
car is 1994
some weird symptoms in the car...
# 1
when I slow down for a speed bump , I put the gear in neutral to downshift , the idle sometimes goes too much low which cause the car to shut off !! and sometimes it stays normal and nothing happen.
# 2
when the car is idling I can notice little flickering in the lcd display and interior lights and sometimes I notice the voltage drops for a second and goes back to its position.
any help
# 1
# 2
any help
When the car is idle and the voltage drops on its own does the engine run worse? or stays running fine for the the moment it drops off ? sounds like the alternator maybe going bad . If you did any work under the hood make sure your grounds are hooked up .
I'll check the grounds
