Is 12's possible with my set-up?
1 Post
Well the good air is finally here and it is time to run the car one last time. I have a track rental at Atco next month and its a pretty good bet that we will have some negative da conditions. My current best is a 13.59 @ 102.65 (2.1 60' & 3522 race weight) in 3000+da (mods in sig) with some drag radials. Since that run I've got rid of the stock clutch in favor of a Comp stage 4. Ive also had the t56 rebuilt to stage 2 specs. As far as suspension goes I have added lca relo's and comp eng drag shocks. I have also taken out another 100lbs or so by !a/c, alt relocation, !sway bar, and drag lites for the front. The car should also have an ewp before I run it too.
It put down 293rwhp and 338rwtq on a dynojet a month or so ago.
My question is, do you think that all of this combined is enough to get me 12.99 or better? Any feedback is appreciated. No trolling please (that means you Smash and Adam )
Yes e-town. I'm starting to have second thoughts. I may call it a year for now and come back in the spring with my 12bolt and 3600 converter. I'm starting to have bad feelings about my 10bolt being called to the gods lol
Yea I keep telling myself that ^^^ but once you see one grenade in front of you, you start looking at it different. I saw my friend blow his on a 3rd gen. Alittle less power then me but on a lighter car. He runs mid 12's at a similar or less mph. Then again he had over a hunderd or so passes but no real street miles. Idk would like to go one last time this year before I start changing things
I speak from experience MANY 12,11 and 10 second cars running 10 bolts cutting 1.5-1.7 60' times. I went a long time on my 3.42s switched to 4.10s then ripped the teeth off of the ring and pinion 6 months later that's a 6spd..... An a4 with no stall will not hit hard enough to damage the 10 bolt.
