gauge pod options?
gauge pod options?
I am getting trans temp, and A/F gauges for my LTZ. I hate my stock fuel gauge so i was also going to get a new fuel gauge while im at it for my 94Z. Summit only sells dual pod for a 94Z, so i wanted to put the fuel gauge on a steering cloumn mount, it seems like the most logical place. Do they make a tripple pod for 94LT or a steering column pod? Searched cant find anything. Thanks
this is the radio delete panel i just made. Ill have a E- fuel pressure gauge and a/f in it and it will be painted.
Edit: i dislike A pillar gauges. Just has a rice to it that i dont like. Thats just a personal opinion.
That is a triple pod for a t-top car only, anybody use it for a hardtop car? Did it work? Are there any pillar pods for a hardtop car...i don't see where the difference would be?
This isn't a pillar pod but it gets the job done and looks original..
http://6litereaterdesigns.com/store/...roducts_id=261
hashtagBMW
You can do the Pillar, HVAC or CD/Cassette area for locations.
The 1LE or more so custome CD area is easy to do and gives you a bunch of room. I had a dual pod with my trick V gauge and dynotune fuel pressure in my car. Considering the trick had a .5v input for W/B, thats all I needed.
Ok thanks for the input guys. The car is a t-top so should i be able to do a 3 pillar pod? If not, im going to do a dual pillar pod with trans temp and wideband. It seems they dont make a steering column pod for these, anyone know for sure? Id really like to put the fuel gauge right behind steering wheel.
