Valve cover sugguestions
Im in the market for valve covers bc some dummy bent mine with a screw driver. Anyone know where to buy a good set or any sugguestions for some? not really looking for anything crazy. I did find some fabricated ones but they dont have the oil filler hole. Im not much on mechanics but how would i fill the oil with no filler hole?
If you do run them and have the alternator in the factory spot you also need the notch on the passenger side valve cover for clearance. I have seen push in style oil fill caps they sell at jegs or summit but you would need to drill or holesaw a spot for it. Then you would still have to drill a spot for the pcv if your running that as well or breather filters.Or the other option is if you know someone who can TIG weld, you can have them weld a threaded cap this is what I'm doing to my fabricated covers.
Uploaded with ImageShack.us
This is what I used without cutting the valve cover. All you do is take an angle grinder and grind a little bit of a bolt off the back of the alternator and boom fits like a glove.
i love the black ones i just cant do the chevrolet stamping in my trans am even tho its chevy power.lol I went with a generic aluminum one that had all correct holes pre drilled. and will probably sand blast them and etch prime em and paint em black with ghosted in 383 CI ball bustin, *** hole ripping, powerful machine lol
Here are a few pics of my cantons with the notch for the alt.
http://www.fquick.com/garages/viewga...d=36180&page=2
How 'bout the cheap ole' ball milled valve covers. Take the milling machine and cut the ball milled area out. Take a band saw to the cover for the alternator notch and TIG a piece of metal in there. Glass bead and coat with crinkle paint. Polish and inlay a piece of stainless with a Corvette wheel center decal. Retired and have too much time on my hands.
