What Rockers??
Old 12-09-2011, 05:10 PM
bm19's Avatar
Hey my cousin has a trans am LT1..he has a CC503 cam to install but he doesn't know what rockers to get self aligning or not?? also its stock heads complete stock motor only has headers so does he need anything else besides rockers and springs?
also what about lifters? should he stay with the 503? cause he wants a 306 but i think its too big for stock heads? not sure if im right but you guys can let me know so i can tell him lol
Old 12-09-2011, 05:29 PM
BIGCAT7274's Avatar
he will need a self aligning rocker. if the lifter are low miles he could reuse them. he should also get the proper springs for the cam he is going to run.
Old 12-09-2011, 05:35 PM
bm19's Avatar
no new pushrods or anything like that? hes getting comp cam beehive springs i believe
Old 12-09-2011, 06:43 PM
Luke1996ta's Avatar
306 is big for stock bottom end that cam needs to spin high rpms to make power an u could go with new push rods but not needed
Old 12-09-2011, 06:56 PM
blackthunder50's Avatar
I installed a cc503 about a year ago, here's what you want:
- 7/16 NSA 1.6 Scorpions (or whichever brand you want)
- 7/16 ARP studs
- Comp Lifters
- Comp 918 Springs
- New valve spring locks,seats,seals
- Trickflow hardened pushrods
- Trickflow guideplates
Have fun!
Old 12-10-2011, 12:25 AM
Zlow28's Avatar
dont get self aligning rockers. Blackthunders list is good. Get any 1.6 NSA rockers and trickflow guideplates.
Old 12-10-2011, 05:08 PM
bm19's Avatar
what about the stud? 3/8 or 7/16...everything is stock so he wants to know which one?
Old 12-10-2011, 08:11 PM
wysemunky's Avatar
the stock stud is 3/8 but 7/16 is more stable and new studs are a direct drop in.
Old 12-11-2011, 10:56 AM
RamAir95TA's Avatar
Follow blackthunder's list, except go with OEM lifters (LS7s). I'd recommend the Comp Pro Magnums though.
Old 12-11-2011, 01:54 PM
bm19's Avatar
ok thanks imma let him know..you guys are a huge help!!..imma post a video of my car later today because i need some help identifying a noise im hearing soo keep a look out lol
Old 12-12-2011, 02:22 PM
gregrob's Avatar
I would do new pushrods for peace of mind... They need to be hardened if you're going to use NSA rockers.
Old 12-12-2011, 04:07 PM
bm19's Avatar
what size push rods? going with 7/16 rockers and studs
Old 12-12-2011, 04:21 PM
Gojira94's Avatar
If the heads have never been off, or if you're pulling them to do the springs (you don't need to) and you're installing them back with no change in gasket thickness, stock sized PRs are fine (7.2").
You don't need to pull the heads to change springs, of course. Just rotate the engine so the cylinder you're working on has the piston high enough to keep the valves from dropping while you change springs.
Old 12-12-2011, 04:25 PM
bm19's Avatar
ok i dont plan on taking the heads off i mean im changing the cam and im having someone do this so hopefully they dont take the heads off either if they dont have too lol thanks
Old 12-13-2011, 11:59 PM
Blk98Vert's Avatar
Self aligning are perfectly fine for that cam, this isnt a 23x/24x cam spinning above 6500. Some Comp Pro Mags and LS7 lifters will work just fine. Also the 306 isnt too big for stock heads, it just has lazy lobes so not a lot of people like to run it. LT1s respond to more duration, not so much lift
Old 12-14-2011, 01:44 PM
bm19's Avatar
can anyone guide me to some Rockers that are cheaper...he isnt doing a highend build so he just needs some 1.6 rockers decently priced also where he can find hardened pushrods...thanks!!
Old 12-14-2011, 02:03 PM
ahritchie's Avatar
Hmmm....I just stepped up my cam from a lunati voodoo 60121 to a 60122 (231/239) and still have self aligning Comp Pro Magnums; is that going to cause issues at higher RPM's as opposed to NSA rockers? Somebody elaborate on this. Also, are hardened pushrods required for SA rockers or are stock ones OK?
OP, do NOT advise your buddy cheap out on rockers...trust me I know from experience LOL. Both summit and jegs have hardened pushrods; can't beat their service or shipping.
Old 12-14-2011, 02:15 PM
Longbob's Avatar
You don't need hardened pushrods for self aligning rockers since self aligning rockers don't use guide plates. The rubbing of the pushrods on the guide plates is why you would want hardened pushrods.
Personally, I like the non-aligning rockers and guideplates better on my Stock Elim motor. I felt I got better lash readings since I don't use narrow feelers. Now that we can go to roller rockers, I am already set up.
Old 12-14-2011, 02:29 PM
bm19's Avatar
im not advising to cheap out..he just wants rockers for a decent price not high performance rockers that are very expensive lol so im told SA rockers are ok to use and not ok to use...what his best bet for the long run...SA or NSA rockers?
Old 12-14-2011, 02:38 PM
Luke1996ta's Avatar
It's dosent matter if they are SA or NSA as long as u have to right hardware either one is it just as good as the other y not get harden push rods they arnt that expensive and it's cheap insurance yes stock would be fine but for what they cost for harden ones go with the harden one Are u sure this is for your FRIENDS car? Or is it yours
Quick Reply: What Rockers??
