Bought a 96 SS Camaro... What to do w/ 2k
Old 01-10-2012, 06:45 PM
effbodySS's Avatar
Default Bought a 96 SS Camaro... What to do w/ 2k
I just bought a 1996 Camaro SS LT1 with a Auto. The car is straight and is completely stock with 135k on it. It runs great and pulls hard. The auto shifts great and was rebuilt as 95k by a dealer.
This is a budget build of mine and I was wondering what you guys recomend? I can do the installs myself so I know that will save a lot.
2K spending...
I want the car to be a fun drag car/ driver... It is not my only car so i am not affraid to break it
How much nitrous can it take safely? Original engine... It has the 3.23 gear option and I was wondering would be worth doing a 3.73?
Also is the stock SLP exhaust worth keeping with long tubes and ory pipe? Does it sound good? I like the look of the stock exhaust.
Here is a dirty pic of what it looks like as I got it. Im getting the Bumpers, hood, and decklid repainted... Goes in tomorrow for that. Not part of the budget 2k.
Thanks for the info.
Attached Thumbnails Bought a 96 SS Camaro... What to do w/ 2k-96-camaro-ss.jpg
Old 01-10-2012, 06:48 PM
97badass's Avatar
No pics, and put a good rearend in it and suspension. Then make it go fast later
Old 01-10-2012, 06:50 PM
97badass's Avatar
On a side note I have a great camshaft for your car. $200 shipped. Lloyd Elliot custom grind 226/234
Old 01-10-2012, 06:53 PM
effbodySS's Avatar
I was looking in the classifieds and saw some good suspension stuff I was gonna make a call on. Is the 10 bolt complete junk or can i get away with doing gears and running it for a while?
Thanks
Old 01-10-2012, 06:57 PM
97badass's Avatar
It's a ticking time bomb. Your fairly safe now with a stock car and automatic. But you start adding power and sticky tires it will break.
Old 01-10-2012, 07:05 PM
ULTIMATEORANGESS's Avatar
id get a stall and LTs.
lt1 SS's were the cars that made me want a 4th gen. yours is nice.
Old 01-10-2012, 07:09 PM
TransAmWS.6's Avatar
Thanks
You can do it, takes a good bit of power to break one in an A4. I would take the money and buy an O/R Y + LT's, hook it up to the awesome stock 2OTL catback, then get a dyno tune. After that I would just get some good tint on it, get some lowering springs, shocks and possibly some quality sticky performance tires if you can squeeze that in there. Awesome looking car BTW, I love those.
Old 01-10-2012, 07:15 PM
01 CamaroSS SLP's Avatar
Seeing how you have a auto I wouldn't worry about your rear end too much, plus you said your not worried about breaking stuff so I couldn't replace it seeing how its not broken. I agree with orange, a stall and LTs with o/r y sounds like a good start. I don't know much about the stock cat-back someone else might be able to charm in on that. Maybe the Lt1 section would be a better place to ask.
Old 01-10-2012, 07:23 PM
^^It's a good catback, sounds awesome and it's a straight through design that is said to actually flow very well, I would keep it if I were the OP.
Old 01-10-2012, 07:26 PM
Smile
my SS still has its OE SLP DD. i like it alot with LTs.
Old 01-11-2012, 07:26 AM
ks my ss's Avatar
Dump the stock manifolds and the dual cat y-pipe.
Old 01-11-2012, 07:31 AM
whytryz28's Avatar
Suspension -> stall -> gears -> cam swap
Old 01-11-2012, 07:44 AM
effbodySS's Avatar
Ordered Air Foil, 160' thermostat, 4 emails out on used long tubes and Y pipe. Eyeing suspension parts in forsale section... Thinking of powdercoating wheels black (200.00) and tinting windows while out getting paint work done. Also ordered window motors.
How much slower with auto X suspension make this thing vs Drag in the 1/4 mile?
Old 01-11-2012, 07:51 AM
97badass's Avatar
Nhra won't let you tint the windows iirc...
Old 01-11-2012, 08:34 AM
Village Troll
SS RRR's Avatar
If it has Level II suspension, leave the rear shocks and all springs in the car. Put some good LCA's and relocation brackets in, tubular/chassis mount torque arm and a one way adjustable shock along with a good rear tire like a QTP or ET Street. I run 27X15" QTP's and above is what I've done and have been running 1.55 to 1.65 60' times in a manual. I have Koni one-way adjustable shocks which are on the loosest rebound setting yet the car still handles like a champ around corners.
Old 01-11-2012, 09:50 AM
guppymech's Avatar
That's a nice lookin' Hardtop.
I think with 135k on it unless you know the maint history you should give it a good tune up. Opti or cap and rotor, plugs, wires, o2 sensors and maybe a new water pump to protect the opti. These items are going to run around $700. Then headers, cai and tune will get you started, you'll still have some left of your 2k but it goes fast.
Old 01-11-2012, 10:04 AM
blackjack325's Avatar
Suspension, long tubes, tune. 3.73 should be a good bump. My 30th came with 2.73!!! Can't wait to swap in the 3.73's
Old 01-11-2012, 12:01 PM
Mississippi's Avatar
Nitrous, stall, gears, end.
Old 01-11-2012, 12:18 PM
ahritchie's Avatar
It won't be slower at all if you pick the right suspension components; should improve quite a bit actually...unless you are comparing it to a drag specific setup with drag launch springs and shocks....then the difference will be huge on the track; .5 sec or more probably.
I have lowering springs, subframe connectors, boxed control arms, panhard bar, LCA relocation brackets (auto x setup) and it hooks up much better than stock. Drag launch springs dramatically improve launches, but the car won't handle for **** around a road course.
Old 01-11-2012, 09:21 PM
stuart4185's Avatar
subframe connectors, lower control arms, lower control arm relocation brackets, torque arm that doesnt mount to the transmission, sway bars, and 100 shot of nitrous. as long as you dont have drag radials or slicks on the car, the rear should last a while as long as you dont do the 373's. thats when they break.
Quick Reply: Bought a 96 SS Camaro... What to do w/ 2k
