stupid oil pan!!!
stupid oil pan!!!
I'm in the process of removing the oil pan and at this point I'm considering removing the steering gear assembly to gain more clearance b/c the engine won't lift more than 1" before the engine hangs up on something.
Anyone else have to go to great lengths to remove the pan?
I'll look for a write up (haven't done it before), but I assume the procedure includes removing the shock tower bolts as well.
k-member to body = 4 bolts
shock tower mount = 2 bolts ???
Never mind... just found a post with a good write that describes 6 cradle bolts. Guess I'll have to wait until I get home tonight to play "where's Waldo" with the k-mbr bolts. But still hard to visual lowering the k-mbr and not touching the shock tower bolts.
For me, I couldn't get my pan completely off unless it was at TDC #1. The pan would come back and like hang, then I figured out it was hanging on the crank, so I spun it to TDC #1 and it came out.
