LT1 4L60e and LS1 4L60e Transmission
Old 03-29-2012, 03:59 PM
davidc212k's Avatar
Default LT1 4L60e and LS1 4L60e Transmission
What is the differences with LT1 4L60e and LS1 4L60e Transmissions.
I am doing an LT1 to LQ4 swap.
I was told that i need to get a LS1 4L60e transmission for it to mount with the LQ4 and the Torque Converter.
Is there any work around for the LQ4 Engine to fit my 95 camaro 4L60e?
Is the bell housing different or what?
The following users liked this post:
Mel-18 (01-17-2020)
Old 03-29-2012, 04:23 PM
gregrob's Avatar
Won't work.
Old 03-29-2012, 05:05 PM
nitrous2fast's Avatar
I thought there was a flywheel adapter???
Old 03-29-2012, 05:28 PM
davidc212k's Avatar
Can someone explain the reason why?
Old 03-29-2012, 05:45 PM
davidc212k's Avatar
whats this for?
http://www.ebay.com/itm/700R4-Early-...821499&vxp=mtr
Old 03-29-2012, 05:51 PM
davidc212k's Avatar
i also found this.
http://www.jegs.com/i/GM-Performance...oductId=835483
Old 03-29-2012, 11:58 PM
Chrisd000111's Avatar
I had someone tell me that the ls computer wouldnt match my 94 trans because the 94 had one less solenoid in it, so the trans has to match the computer
Old 03-30-2012, 01:22 AM
93Z2871805's Avatar
You need a 96+ 4L60E to work with the LS computer (unless you want to go with a manual valve body). Cheapest way would be to just grab an LS1 4L60E.
Old 03-30-2012, 01:47 AM
the_merv's Avatar
95 can work with some re-wiring, 96-up will work without modification.
Use the LS car/1500 truck Flexplate, spacer on back torward Trans.
LS 2500 4L80E Flexplate, spacer on Crankshaft.
Make sure you have the correct bolts for both.
Old 03-30-2012, 02:03 AM
93Z2871805's Avatar
You'll need the 12563532 spacer. Some aftermarket flexplates use a dual pattern that will fit either the old or new style converter holes (such as the PRW 1834610). You'll also need 6 longer flexplate bolts (19257940).
Old 04-22-2012, 11:47 PM
uneek1976's Avatar
What kind of wiring would have to be done in order for the 95 trans to work with the LS1 pcm?
Old 04-22-2012, 11:55 PM
WS Sick's Avatar
Yep need a 96 -97 for no wiring changes, and the flexplate needs a spacer. I actually did the oposite once, I put a 99 4L60E behind an LT1 in a 93 S-10.
Old 04-23-2012, 06:51 PM
flame's Avatar
There is no difference in the wiring as long as you have a 95+ trans you are good to go. See the attachment for the wiring left is 95 right is 96 where is the difference? There isn't any!!
Old 04-23-2012, 06:57 PM
WS Sick's Avatar
I was thinking 96 was the year they added the PWM but obviously by the wiring chart the 95 has it, I know the 94 doesnt.
Old 04-24-2012, 10:57 AM
maddoglou454's Avatar
Default What is the difference between a 4L60E or a 4L65E
:d:d:d:d:d
Old 10-13-2012, 11:17 AM
TypeSL2's Avatar
I have read so many threads today that I am just getting more and more confused. We are swapping an LS2 into the wife's '62 Impala. Originally the plan was to use a 700r4, but after doing some digging found that I could purchase a 4L60e from the local junkyard at a very reasonable price.
Question Is there a difference between the 4L60e transmissions on the V6 and the 4L60e transmissions on the V8? If so, how can we tell which transmission will bolt up to our LS2? We already own the spacer, flex plate and bolts. Thanks in advance.
edit: I also found this link at some point today.
http://www.novak-adapt.com/knowledge/4l60e.htm
If I read this link correctly, it states that the GM 4.3 and the LS are both 90* V motors and that the bellhousings do not change and are therefor compatible. Please tell me if I am right or wrong. This info will help broaden or narrow our search quite a bit.
James
Old 10-13-2012, 11:25 AM
whytryz28's Avatar
Bolt pattern on the V6 is different from the V8, V6 has a 2-piece case also.
Old 10-13-2012, 11:44 AM
TypeSL2's Avatar
From that link, it looks like the 2.8 v6 is the only one that has a different bolt pattern. The 4.3 looks like it shares the same bolt pattern. What do you mean by a 2-piece case?
James
Old 12-11-2013, 10:06 AM
davidc212k's Avatar
I will end up using a 97 LT1 4L60e guys for the very helpful hints.
Old 12-08-2014, 09:43 PM
Iroc_Rat's Avatar
So basically your saying that if I had a 2001 5.3 and a 1996 4L60e Tranny,it will control it? or do I need a flex plate for that too?
Quick Reply: LT1 4L60e and LS1 4L60e Transmission
