Whats that silver box under the dash
I just tore down a buddies dash and replaced the wiring with a Painless harness. Pulled out and ID'd every module - the BCM is on the driver side tucked up in the corner. It's a silver box with a pretty big connector (2x16).
There are several other modules under there, some located on the passenger side, some on the driver side. RAP, airbag, TDM, BCM, etc.
I am looking at my factory service manual (for my 95) and it distinctly shows a BCM, location, diagnosis, etc. Location description says "above driver side kick panel" and there's a pretty diagram that shows its exact location - precisely where the OP says it is.
The OP says it's SILVER, not BLACK. The BCM is silver.
It's the EBCM (Electronic Brake Control Module) not BCM (Body Control Module) that on the left side of the dash.
The BCM is on the right.
Both are silver, IIRC.
