Coolant Sensor light came on.
My cooling light sensor on the dash came on and I'm pretty sure its a gummed up sensor in the radiator cause coolant level is fine. Where's it located because I can pull it out and clean it etc..anybody got a pic of where's it located? thanks
There is a sensor, but you could unplug the wire going to the sensor that keeps the light on on the dash. That's what I did because I can't stand lights showing on the dash. Or you could replace the sensor or try and clean it. If you looking at the radiator from the front of the car, it will be to your left side just behind the filler cap. Well, at least that's where it's at on LS1's...
