hay i have a ? about lt1 rods??
hay i have my 1992 camaro rs im building a 350 gen1 sbc for it it came out of a subrben its a 4bolt main roller motor and has the 5.7L on the back of the block. My ? about the lt1 rods is what year to look for the powder rods that i have seen about any helps is a thanks.
I have torn down at least one 94 LT1 that had pink rods, I believe the change was either sometime in 94 or for 95.
Honestly for the price of rebuilding stock rods if piecing a new setup together I would just do an aftermarket Scat rod, maybe get something bushed and save the cost of pressing pistons to the rods.
It is one thing to reuse them if refreshing a stock shortblock, another to seek them out for a budget build and I would not bother for the later.
ok
well what would you use?? im kinda going for a stock block thing to prove a point and i can do most of my motor work myself ,just need some info light boost will be throw at the motor maybe only looking for mide to low 12s its a dd so nothing crazy
Honestly rod failures are more often tension failures than pressure failures, meaning rpm and piston weight have a LOT more to do with it than HP.
The "pink" rods were the factory high performance rod for a few decades before we had good reasonably priced aftermarket options. I would not split hairs over pink vs. PM rods for the LT1 because IMO you aren't going to find a performance difference, they are both decent rods. Honestly I might ask my local shop I planned on using for the resize if they had a preference. Because if you ask them and then have a problem they are going to be a lot nicer than if you bring them something they don't like and have them work on it and then have an issue. Should be noted too that the PM rods take a different ARP bolt, I don't have the PN handy but there is a PN just for the PM rods.
ok well im not looking for any think much more then 400hp at the wheels. I think i can get mid to low 12s with that maybe i don't need even that much ,i got my supra that run's 10s to go fast ,just tired of my 3.4l v6 that's got heads cam headers and intake work with a tune that only runs 15.30s.
thanks for the input and help ls1tech/lt1er's
