It's an LE 242/248 110lsa 580ish lift. It's the cam LE Spec'd for my 383 build. Man I thought that just seemed high for street oh well. Will a stock starter eventually go out starting something with 12.5+?
Well I Got a mail tune from Ion. I got the tune hoping it with get me to the nearest LT1 turner (about 2hrs away). Think it will be ok with that tune driving for 120 miles? Or should I just rent a trailer? Good to know about the starter thanks 96caprice.
If I milled the heads I thought it would increase the compression? Is this backwards? I guess I could just go with a thicker gasket if I needed to lower it.
Just curious, what heads are you running for this build?
Running an LE2 set of stock casting heads 54cc. LE did say this cam loves high compression. I just wanted to know if I need to only run high octane or if 93 would be ok.
