Rocker not centered
Old 08-24-2012, 06:03 PM
notsosanestan's Avatar
Default Rocker not centered
okay so i just got my car going and the front passenger side rocker ended up hitting the valve cover... i have pro mags 1.6 and canton valve covers. Now the rocker isnt lined up on the valve. The guide plate looked crooked so i fixed that and reinstalled both rockers for that cylinder. The rod isnt bent but the rocker does have a small chip on the bottom of the rocker where it seats against the stud and the stud has a little bit of rub marks where the chip is.. Im going to replace both rocker and stud. just curious if it could be something else besides the chip and rub mark making it off center? really sucks this happened but gotta fix it.
Old 08-24-2012, 09:08 PM
shbox's Avatar
What guideplates?
Old 08-24-2012, 09:17 PM
93 LT1 Vette's Avatar
I'd pull the rocker stud and check the threaded boss in the head for cracks and the stud for straightness just to be safe also.
Old 08-25-2012, 07:43 AM
The rockers are NSA with gm pn 14011051 guide plates. Kinda wish I just got SA rockers now :/
Old 08-25-2012, 09:52 AM
SoxXpupPeT's Avatar
Do you have an overview picture of the rockers? SA rockers are ok for an engine that isnt going to see a whole lot of abuse. SA is the only way to go if your going to rev the engine like a bat outta hell!
Old 08-25-2012, 10:10 AM
guppymech's Avatar
Originally Posted by SoxXpupPeT
Do you have an overview picture of the rockers? SA rockers are ok for an engine that isnt going to see a whole lot of abuse. NSA is the only way to go if your going to rev the engine like a bat outta hell!
Fixed.
Old 08-25-2012, 12:08 PM
TwoFast4Lv's Avatar
I found a sure fire fix for those problems!
Old 08-25-2012, 01:37 PM
Wow, now thats what I call a fix.
Old 08-25-2012, 02:00 PM
englundjd's Avatar
ooooooo thats pretty! problem solved... for you
are those hard to adjust?
Old 08-25-2012, 07:56 PM
defaultexistence's Avatar
Now THAT'S just Bragging
Old 08-25-2012, 08:11 PM
TwoFast4Lv's Avatar
Ok ok. This is the second best way I have found to align LTx rockers. Be uing them for 14 yers or so. They have to be tack welded once setup but I hae yet to gt a quieter valve train then this set wil give you.
Isky 200-AGP
Old 08-25-2012, 10:57 PM
StraightTimeStirrups's Avatar
How about a detailed explanation of what you have done?
Old 08-25-2012, 11:51 PM
TwoFast4Lv's Avatar
Which part?
Old 08-29-2012, 03:39 PM
here a pic for you guys. ordering a new trunnion on a couple days from comp cams only was 2.50$
Old 08-29-2012, 08:09 PM
spcearle's Avatar
That's the same way mine looked ... Went with the isky adj plates and a few hours of grinding and adjusting to get it just right and now they are perfectly inline
Old 08-29-2012, 08:21 PM
how many of your rockers looked like this? All the others are lined up perfect.
Old 08-30-2012, 10:02 AM
spcearle's Avatar
If I recall it was either all the intakes or all the exhaust
Old 08-30-2012, 08:27 PM
wrd1972's Avatar
The Isky guide plates are the only ones that will center the rockers up assuming you do it correctly. It took me nearly eight hours but my rockers are spot on.
Old 08-30-2012, 11:09 PM
TwoFast4Lv's Avatar
If the engine is on the stand it goes fairly fast(1-2hrs) If they are on the car it can be a PITA
Old 08-31-2012, 09:10 AM
wrd1972's Avatar
10X
Quick Reply: Rocker not centered
