Car showing -18* timing...
Looking for some ideas on why a 1996 LT1 Camaro would be reading -18* timing at idle and going to -30 when driving. I know there is no way the car would run and drive like it does now if the timing was truly off as bad as it shows. We did a motor swap, just went to a little built LT1, and the computer started to go weird. Any ideas or thing to try would be helpful.
Thanks,
Chad
Thanks,
Chad
Different scanners or software may show it with a minus sign or no minus sign. They may call it timing or may call it advance. Either way, the amount is always going to be a negative (BTDC). Your engine cannot run any other way.
Ok thanks guys! I should have have figured that out, but we have had a issue with a motor not talking to the computer with a FAST system so I over complicated it from the start.
Thanks,
Chad
Thanks,
Chad
