what do yall think about this combo.
hey yall,as mentioned in my introduction,a friend of mine is wanting some wok done for him. he's a good guy,just dont know a whole lot. anyway,hes wanting to run in the 11's,so i thru this together for him. what do yall think it will run and dyno?
moroso cai
Trick flow elbow
summit 58mm tb
edelbrock lt1 air gap intake
1.6:1 roller rockers
new valve springs.
Comp CC306
Pacesetter LT
Magnaflow 3" cat-back exhaust.(tryin to talk him into a loud mouth kit and an ORY pipe.)
and of course a tune.
its gonna be a stock bottom end and stock heads.the engine is new. the guy he bought it from just replaced it and yes he does have the recipts for it.its an M6 car with 3.42's. what do yall think?
btw,what do yall think about this spring kit?
http://www.alexsparts.com/lt1-valve-...rs-locks-cups/
moroso cai
Trick flow elbow
summit 58mm tb
new valve springs.
Comp CC306
Pacesetter LT
start ur list at the 1.6rr skip all of above that, its a waste of money. There is no way u will make 11s w that combo u will need to do the heads as well so save ur money on all the fluff stuff that doesnt make any hp, such as the first items on ur list. U are gonna have to do a pretty large H/C/I combo to do 11s with no power adders. GLWYB
ive told him he will need at least a set of 3.73's as well.
thats kinda what im doing.
http://www.youtube.com/watch?v=cmZ0-0cqoYA
whats so bad about the intake and 58mm TB? im not tryin to be a smart ***,i just really dont understand.im used to Gen 1 SBC where just about any intake is better than stock.lol
Stock tb and intake are not a restriction till aprox 400 ish hp. Money would be better spent somewhere else .
Put that $500 toward a good rear end. Cause it be hard to run 11s with stock 10bolt and m6. Also when he buying rockers. Go ahead and up grade to a 7/16 rocker and studs. Make sure you buy nsa rockers with guide plates. 11s should be easy with cam, bolt ons, and good 60ft. So make sure to spend some $ on the susp. Good luck
seeing as everybody is agreeing that there are VERY large issues with your plan and granted making solid recommendations about what you should use instead.. What I would still tell you is STOP right here and do a LOT more research before you plan another magazine build like this that cost a lot and does a lot less than it could have with good parts..
If this was the plan you guys had come up with then you are not quite ready to dive in yet. We all started somewhere and most of us look back and with we had been a little more patient early on and avoid some of the mistakes we made.
