After almost 3 years it is finally alive!!
What started it all.... a bad injector causing a lean condition for number #6
388 with AFR 227 comp heads, Cogged F1A, LT4 edlebrock intake, 4L80E with a brake, etc
I hope so! I maxed out the 95# injectors today. I havent run it on the dyno yet so i dont have the HP numbers. 95# injectors support about 925-950 Motor Hp at 43.5 psi
Looks like an impressive build. Great to see some builds taking off again this board seems to be lacking it lately and is boring.
What are you running for an ignition system? Video is kind of blurry to make out but looks like coil on plug of some sort... ltcc, delteq, or EFI 24x?
Keep up the good work
