blew up the 10 bolt
blew up the 10 bolt
Anyway to the point..I got on it couple blocks from the house 1st-3rd gear when i was decelerating it was making some awesome sounds.
Luckily i have a set of spare 410s and a spare posi..so tomorrow i will be tearing into it..
on second note....what would you guys recommend for a rear end...strange, moser ect...?
Village Troll
Only problem I've had with my Strange 12-bolt in the 13 years I've owned it are the spider gears in the HD carrier breaking twice at the track. This is after about 20 outings within that time frame. Lots of 1.70 60' launches and a hand full of sub 1.6 in a full weight car as well as countless launches on the street with Nittos FWIW.
i'll post pictures tomorrow..got the gears out and housing cleaned up. The pinion gear had half the teeth gone and the ring was evenly chewed up all the way around. Had to order a new pinion nut and will put it back together with the 4:10's tomorrow.
Was thinking of going with these 3.90's after they were REM polished and cryo'd.
http://www.summitracing.com/parts/mgr-g975390
