Anyone know the LT1's "Oil Pump Drive" Dimensions ?
All -
My oil pump drive failed - the plastic portion broke at the hole for the hold-down bolt.
So, I replaced the unit - no problem.
However, after I buttoned everything up, my brother suggested machining an Aluminum unit for me, and I only had the old / broken unit for him to measure.
So, can anyone give me the spacing between the two holes on the top of the oil pump drive unit and the thickness of the plastic material around the hold-down bolt?
Thanks!
Thanks!
I have a stock one with a metal holddown
Both units I've purchased from the local Chevy dealer were metal shafts encased in plastic. Was yours a 'special' GM High Performance unit?
If so, do you know the P/N or can you get me the dimensions I need so I can have my brother fabricate one?
LMK - Thanks!
LMK - Thanks!
Just buy one of these for the stock unit. Made by a member here. http://pro-jectioneng.com/ Far less expensive and just as effective.
Thanks for the info!
