Optispark wobbles
Optispark wobbles
I just Changed my optispark to a msd unit and when i start the car up i see that it wobbles a bit, is that normal or did i forget to tighten a bolt?
Before i remove the waterpump again to check for loose bolts it would be nice if someone could check to see if there opti moves around a bit whith the engine running or if it stays still
If the rest of the engine is wobbling the same amount, in the same direction/s, you're probably ok.
Get the drive pin in the correct slot of the MSD.
Read on forums that happens quite a bit - the cam drive pin gets stuffed over the wrong dist slot and clamped down with the dist bolts. That MSD/Opti needs to sit flush on the timing cover. Don't force it down with the mounting bolts. The stupid thing does have 3 grooves in it but u have to get that drive pin in the "indexed" groove on the back of the Opti - its larger and the drive pin will fit in it - not the other 2 grooves.
Good luck and hope it helps,
cardo
