Recurring Power Steering Woes
I had to change my power steering pump after my cheapo harbor freight puller pin got stuck in the old one (literally would not come out. Automotive equivalent to Excalibur.) Before the pump swap it ran great, no noises. I have bled the new pump a billion times and the noise will not go away. It whines like crazy. I flushed the system twice and it's a bit better, but it still whines. Does this even on a cold start up.
Any ideas? There are no leaks to my knowledge. The fluid level does not move, nor do I see and bubbles in the reservoir.
How are you bleeding the system? If the fluid level isn't moving you may have a kinked line or twisted it wrong when reinstalling. How does the steering feel? Like it did before? Heavier?
9-Second Club
Your lucky. Can't tell you how many have been through my shop with whining pumps, many would **** fluid out the vent hole in the filler cap on very cold morning, that somebody had put red transmission fluid in them. That is what was used in power steering pumps in old vehicles. Both Ford (uses a lot of GM built steering components) & GM changed to lighter weight green fluid in the mid '70s. We fixed many of those vehicles by dumping & replacing the power steering fluid with the proper fluid. You can buy green power steering fluid for GM & Fords at NAPA, etc, auto parts stores.
