355?
First off, let me say I've never started a thread, I've always researched old threads for all I need.
That said, I'm buying a newly stroked 355 for a lt4 hot cam kit in it. I'm on a pretty tight budget after buying this engine so nothing crazy. Should I port the heads with LE and keep the lt4 cam? With the bigger engine do I need to buy anything over stock on my intake? If I get a new cam do I need to replace all of the lt4 cam kit?
And what kind of rwhp am I looking at? I'll have a 3000 stall and 3.73 gears.
Its for a fun street car and a future strip car.. Sadly I have no strips close to me.
Oh, and CAI and headers back exhaust, and I'll be changing my tune after I put this in obviously.
A 355 is not a "stroker". It's just a 0.030" over bored 350. You can do better than the hotcam kit. The rockers are about the only decent thing in the kit.
If you go with a bigger cam you need matching springs because the LT4 springs barely cover the Hotcam. If you had LE do the heads just have him spec you a cam too.
Also, give us some more specs on the motor, hopefully it's not somebodies mess that they gave up on and sold to you...
My apologizes, I meant freshly machined not stroked.
"355 lt1 4bolt main block, all fresh machine work, total seal rings, all clevite bearings, crank was polished, scat rods, hypertech pistons. with 12:1 compression and dome pistons."
He offered to send the kit with it for a small amount extra, I figured I could put it in my old motor if I don't use it in this one.
What other specs would you want? I'm not used to bored engines or anything in the short block, I have done a lot of work on the top half of engines before.
get a specific piston PN and deck height.
I am not feeling as positive about this as the other poster.
Hypereutetic domes pistons????
12:1 when he was aiming for a HOT cam???
Domes are for when you are trying to get very high compression, if it has domes and only 12:1 I suspect they wanted to use a very thick gasket and likely not zero decked which will make quench crap and then that much static compression with such a small cam is going to be very likely to detonate.
The 4-bolt mains is basically meaningless, the two bolt is fine until a LIT more power than this thing will ever make. So don't see that as any "added value".
From what your saying do you think I NEED a bigger cam with this cam?
I'm not too worried about emmisions, as long as it isn't SUPER obvious that I fail
I think the compression guestimates are done "catalog style" with ASSumed values for deck height and gasket thickness and a generic combustion chamber size.
You bring up a good point though, most SBC chambers are bigger than LT1 chambers and if his shop ordered pistons that are listed at 12:1 with a dome for a standard SBC, hell they might not even fit in the LT1 chamber much less have useable compression on anything near pumpgas.
Just a quick Summit search says the smallest "dome" hypereutetic piston you can find there is a -.5cc which means the dome is just smaller than the reliefs with a shitty .020 deck height and standard felpro .039 gasket and 54ish CC chamber LT1 heads that is about 11.9:1.
If you go zero deck standard smallblock 64cc chamber 6cc dome and a .039 gasket you come out right at 12:1, but the dome probably wont fit in the 54-56 depending who you ask LT1 chamber.
Basically what I am saying is either you are relaying the information poorly or it is likely this was an ignorant build.
IF and that is a BIG IF it is setup to be 12:1 with LT1 heads and a dome that fits it is still inappropriate for a HOT cam and when it detonates a little from high ambient temps, mediocre quality batch of fuel, momentary starvation because you got on it too hard with low fuel in a corner etc. then it is likely to crack a hyperutetic piston.
Hypereutetic pistons are a great mild to moderate performance piston IDEA but I don't think anyone is actually making GOOD ones which is why for many street builds guys do a 4032 forged like the Mahle Powerpak not as strong as a 2618 but commonly available quality offering without any of the drawbacks 2618 has on the street. That is the good middle ground.
If I were to do a hypereutetic build I would keep the stock pistons. The thinnest rings I saw offered in hypereutetic are 1/16"/1/16"/3/16" which is 1.5875mm/4.7625mm
That is thicker than stock for more parasitic drag and likely more bore wear.
https://ls1tech.com/forums/parts-cla...much-more.html
That's the link to the ad. Just to show some of the information that way its not all relayed wrong.
And thank you for all the help! Please keep bringing it!
to OP: do you have a specific goal other than saving money? What HP or TIMES you shooting for? Or, is it not a big deal... just a fun car that you'd like to run occasionally? Is this an AUTO or M6?
I would eventually like to have 400+rwhp. Its not a goal that I'm overly obessed with reaching. I have never thought of a bigger block due to my lack of knowledge in them and had wanted to do a good head/cam set from someone like LE. But when I saw this I thought I would buy it and use it instead.
MATH!!!!!!!!!!!!!!!!!!!!
quit bench building and just do the damn math............17 posts later and it still has yet to be done......96caprice is correct.......get the piston number find out the deck height and do some math there are a million CR calculators out on the web......just google it.......
also yes 12:1 on hypertutetic pistons is too high IMO but long as the tunes good and u dont spray it and the rings were gapped properly it should be ok
get the following info then come back.......
piston make and part number or cc of the piston?
and how far is the piston down the bore at TDC?
