fan trouble
Old 03-23-2013, 01:30 PM
camarozssclone's Avatar
Default fan trouble
When I unplug the sensor on the water pump fan comes on at start up i have put in a new sensor and plugged it back it fan does not switch on when it reaches the temp it should come on at any clues i dont want to bypass it i want to fix it right by the way thanks for all the info on last post I put new plugs wires and cap and rotor on it fixed my mis fire 2 screws were stripped on the cap and it had worked its way loose I re tapped them and put bigger screws in it she is running strong thanks again!
Old 03-23-2013, 03:26 PM
shbox's Avatar
So, what temp are you thinking the fans come on? 226°? That is the stock fan threshold. Verifying this with a scanner?
Old 03-23-2013, 03:29 PM
tt383lt1's Avatar
right off of the bat i would think one of the sensors are bad. ether the gauge sensor or the ecu temp sensor.
Old 03-23-2013, 10:39 PM
DisasterFormula's Avatar
Okay, so you put in a new ECT (engine coolant temperature) sensor and the problem didn't go away. 1. Have you properly, completely, and repeatedly bled your radiator? 2. Have you verified the temperature is correct? The gauge on the dash is rather inaccurate.
Old 03-24-2013, 02:59 AM
Yes I have bed the system no air in it at all if I'm running ect sensor unplugged it runs great at low temps . The cut on factory is 226 yes which is about half way on guage give or take it don't come on it will over heat get to 250 if fan is not on all other stuff is hooked up right and it works correct as long as fans are on just over heats when fan won't cut on at needed temp yes have checked temps by other means other than guage via laser thermometer its for sure getting hot hooked to obd1 code reader its throwing no codes ????? What's next. Thanks guys
Old 03-24-2013, 09:17 AM
shbox's Avatar
You must use a scanner to see what temp the PCM is seeing and if the fans are being commanded on.
Old 03-24-2013, 02:57 PM
I would like to get a scanner and programmer as I have to Camaros I 94 that's going to soon be a race build and my 95 convertible. Search protree racing1 you tube a buddy of mine built and 8.3 sec camaro I may go that route
Old 03-24-2013, 03:06 PM
By the shbox I love u man u have helped me a lot with your site I love these camaros but I can't afford to pay people to work on them and these cars are a lil different than my older 72 and 74 camaros I used to have so thanks bro!
Quick Reply: fan trouble
