Gm sunroof question
Gm sunroof question
Ok so Weird question but this forum seems to be the best for GM guys;
My brother opened up the sunroof on a 99 Pontiac Sunfire when he was checking it out for his daughter, and now the damn thing won't close. ( Why he thought it necessary to check in 30 degree weather in Cleveland, OH is beyond me, but now I'm stuck fixing it). I pulled off the headliner thinking I could:
A: find a manual crank to shut it
B: try and close it using a jumper wire.
I couldn't turn any Part or bolt or key manually to shut it. When I try to engage the motor with a jumper wire, the solenoid engages for the opening direction, but not for shutting it.
I just need to get this thing closed until the snow and rain let's up. I know this site is normally for Camaro advice, but all the research I could find on the net sucks, and the mechanics I know only work on Chrysler and tell me to find a GM guy to help.
Any support would be great, thanks.
Thanks for the help; turns out there is a pontiac sunfire forum out there... Hopefully its as good as the guys are on LS1tech. Thanks for the help again.
Ok so I hope no one has to deal with closing a sunroof; there wasnt a lot out there and the pontiac forum didn't really get a lot of traffic/views...
I took a chance and dropped the headliner, removed the motor and the sunroof could be manually pushed into a vent position. To drop the glass down into a closed position, there is a bracket on the inside of the track (tricky to access, I found you can use a long flathead screwdriver to collapse it) towards the front of the sliding mechanism attached to the glass. Once I pushed the bracket in it allowed the roof to drop down... Wish I had a video camera to post a video to show the parts I'm talking about. I'll post some pics if I get a chance...
I only cared about getting the sunroof closed. I'm sure it gets more complicated to make it operational but that got the roof closed and a tarp off of the car until the weather gets better.
Good luck if anybody else is reading this to get theirs closed. Thanks for the help from all who replied.
